Jeremy1
:s19:
Today is a very sad day :sad:
I had dropped and lost my charging case :sad:
animeonegai
I just received the cp360 m/L size . The fit is definitely better than the stock but fit test still fail. Noise still can leak in. It's deeper to the ear. And can fit the case.
Soundcore ask me to email the support in sg. I emailed yesterday and no reply yet. :s13:
kazuki666
Brought the moondrop space travel out to test ANC and transparency mode. Been using at home and wasn't satisfied this want to give it justice outside.
I have to first say the results I suspect is likely I can't get a good fit with the provided eartips. Normal mode seems to let it fair bit of sound it which is also why I suspect the eartips problem. Changed to transparency mode let it slightly more ambience sounds but not significant. Switched to ANC mode, it doesn't block out noises like bus and mrt beeps, bus noises at bus stop.
All the above doesn't occur to my daily beater QCY melobuds which even have volume adjust functions which moondrop doesn't. But having said that, it's decent for the low price, and I will still find a casing to hold it since the design is exposed.
Rhytoric
Imo, moondrop is very gimmicky on its design even for their wired iem, qc is an issue too.
I know someone whose moondrop iem spoiled after just 8 months but he still went on to buy the moondrop space travel. They are cheap no doubt but still it's good money wasted
TerryPower
Need recommendation for earbuds with good ANC for mobile phone use.
I currently using Creative Outlier V3. Would be nice to have something with better ANC.
I usually watch YouTube and videos downloaded to my phone.
Edit: Budget is below $70
caterham7
Tried quite a few tws, anc not great, personally think passive isolation more important
If you are willing to consider wired, can get etymotic iem, often on discount during black friday at amazon, bought er2se at $70plus last year
If your phone doesn't have 3.5mm jack, can just buy a type-c dac, can get simple one around $10-15
Rhytoric
Old skool brand sia
Maybe I have not been keeping up with news but those old skool brands dun have tws? Shure, we stone etc, only know sennheiser and klipsch have some tws but they are so expensive
anthonygreenisreal
saw last year ER4SR/XR went as low as $165.
Henabi
Edifier W240TN
animeonegai
Tozo nc 9 or nc9 pro. Liberty 4 NC also good. Both good ANC and long life. Sq hearsay is good also. If got discount, will go around 70 to 80.
