xKazeolus
i have just returned my liberty 4 nc due to fitting issues and when only using 1 side, anc will not be on by default. ya it's reasonable for anc to be auto on when both sides are used. but somehow the sound quality differs a lot with anc on or off. :ROFLMAO:
ParkJinYoung
I'm using Soundcore life P3 and A40
I like both alot and seems like Liberty 4 Pro rated even higher.
I like Beats but seems like everyone's favorite beating boys
xKazeolus
somehow i still prefer FIIL T1 Lite/Pro maybe due to the loud volumes but the fits are one of the best for my ears. Currently riding on with Sony C500
ParkJinYoung
I have 3 FIIL, just couldn't get any good fit until I gave up
How's C500?
I was looking at C700 for awhile
xKazeolus
How's C500?
to add i changed the tips to CP360. C500 sound better than FIIL but the volume isnt as loud. i gotten it as FIIL telecommunication is quite bad. not saying C500 is good but at least the other party can hear me without i screaming.
ParkJinYoung
I can't stand those tws, put to full volume still quite soft
DarthGW
how is soundcore a40? i read on reddit that in terms of sound quality, Liberty 3 pro still better than 4NC. A40 also quite comparable even though old model
DarthGW
IMHO I prefer my Life P3 over A40 although the later has LDAC
any reason for that? i dont mind no LDAC since i am using iPhone. seems like there is a life p3i but local platforms only list the original p3 though
xRenol
I purchased the TOZO Tonal Dots previously.
I am not sure if I received a lemon set or the product functions in this way. When I used the left or right earbud separately, the earbud volume is working fine. When I used both earbuds together, one side of the earbuds' volume will reduce to very soft to the extent of no sound.
The ENC call noise cancellation is still passable because I could still hear some noise.
The calling experience was quite bad because the other party could not hear me even though I am in a quiet room.
In the end, I have to return it.
veltix
Jbl tour pro 2 looks nice and expensive. 300 plus. How many of you are budget buyers? Buying at 80- 150? Also how many of you are expensive buyers? 200 to 300 or beyond?
Henabi
My full review on edifier Neobuds pro 2 coming out on 11th Dec
Edifier NeoBuds Pro 2 Hi-Res ANC Wireless Earbuds Review | Mic Test: AIRPODS PRO KILLER
Description have discount coupons ☺️ courtesy of Edifier Singapore
