veltix
Hi guys which earbud would you recommend me to buy? In terms of long battery case life charge multiple times and longer play time.
musiclifez
Hi, I'm looking for a replacement for my AP Pro (2nd Gen). I personally find the base, mic quality and transparency are enough for me.
Any recommendation on a cheaper alternative ? (maybe less than $200, in-ear prefer as I will be using for sports)
If anyone tried on Huawei Freebuds 5i and can provide some review would be great.
caterham7
u can search youtube using the keywords
tws mic
many reviews of various price range, u can hear the mic quality for yourself
Alpha12
Hi, I just got myself the Bose QC2 earbuds and am new to Bose products. I noticed the following:
When I connect the charging case to a wall charger, it does not start charging unless I open and close the case.
Is this behavior normal?
Henabi
Check with bose on this
not the same as what I saw on Jimmy floss unboxing
DigDub
Yes mine does this sometimes also.
I have the Soundcore NC4 since launched and got it for $78 or something. They make me question deeply why last time need to spend $300 plus for an ANC earbuds.
Imo anc itself is also not that necessary, just need a gd seal which is not that difficult to achieve. All the bells and whistle just to Jack up the price. The sound signature and tuning is the most impt aspect
gregory_choo
if you are in mrt, bus or plane, no choice. passive sound isolation is not good enough.
at home or office, can live without anc
caterham7
FYI only, passive isolation can be good, if you don't mind using wired iem. I use both wired and wireless, still find better isolation with wired
Granted, unfair comparison, as my wired iem is etymotic, which comes with triple flange tips
gregory_choo
what wireless earpiece are you using ?
