Tornesoul
Thanks, any major difference between the Anker Liberty 4NC vs QCY Melobuds Pro?
Looking at shopee ard 100 vs 50
MangoCAT
Bought a local set AZ80 for 344 using the 9.9 mari voucher 50 off 350. Not the best price i saw here, which is 324(not sure is usd or sgd).
Treoo website also selling local set at 359 at their own website.
https://www.loudnwireless.com/soundsamples - the listening test won me thru
For difference genre
One will argue xm5(more bass but the sound is not as clean) and especially the noble (deeper quality bass) sounds better/more exciting due to the bass .
Looking for a clean sound (elite 10 was one of the better choice with excellent ANC)
If you looking for a forward/in your face sound signature --> earfun air pro 4 is quite good and a good steal at taobao pricing. Not as artificial as AirPods Pro 2 for their highs
sumako
how much you pay for your earfun air pro 4?
MangoCAT
Did not bought it but I saw it's ard 79 including gst/shipping. Currently, cannot check out le despite able to add to cart.
The loud wireless website have sound sample for earfun air pro 4
If you can find a forwarder might work
【淘宝】http://e.tb.cn/h.go1PcSyKclMXQ1Q?tk=dql93gJJtK5 CZ3458 「【重磅新品】EarFun丽耳Air Pro4蓝牙耳机无线主动降噪高音质升级」
点击链接直接打开 或者 淘宝搜索直接打开
Whizdom
is the liberty 4nc still the "most bang for bucks" now? any other recommendations?
galliano
Just to share:
Gotten the Jlabs Jbuds mini from Gain City $47 inclusive of delivery.
Wanted to try a cheap pair .. cos I kinda need small ones so that I can wear my motorbike helmet.
Sound quality is pretty ok .. no ANC but the microphone is pretty good.
Anyway, none of it matters when riding a motorbike :p
Have tried AirPods Pro, SoundPeats & Galaxy Buds... all have problems fitting with the helmet. It's either discomfort or primarily the buds all drop out the min I remove my helmet.
MangoCAT
Az80 is 306 from official Panasonic but is preorder. Ended up selling all my tws like liberty 3 pro, Samsung buds 2 pro etc. Left with Samsung buds 1 pro and az80, more of a good sound first and huge shell is okies with me (not having the best anc is fine with me)
Will say Samsung buds sounds way way worse without ssc cos buds 2 pro sounded like chifi tws
Connectit is 311 with a cable if you add a random 7.90 cable(their cheapest item) to topup to 400. shld be ready stock
DigDub
Settled on az80 for quite some time. Very good in all areas. Excellent sound quality, no bugs, decent battery life, good ANC.
tanbrave
hi,
looking for wireless bluetooth EAR BUDS,
meaning like air pods, with just 2 small things to put into your ear without any interconnecting cables,
thinking between the sony WF-1000X but seems like have connection issues and not so cheap
criteria :
battery life at least 5 hrs
water proof or resistant, not going to swim with it but if dirty or get caught in rain, dont have to worry,
sound quality, currently use SHURE 215, more bass person
connection : should have strong connect so that wont keep drop and affect your listening experience,
can anyone share their experience of current ear buds on the market ?
thanks !
Aim brand,suppose to translate at the same time.think ABT 200 plus.
masashi
Currently using QCY HT05, while it's good, I hate how I can't tell when the charging case is charged until today while in the bus, my earbuds totally ran out of battery :mad: Currently thinking about Baseus MA10 for the budget, are there any others I can consider since I'm not paying too much for one.
