artemov
as in spotify only transmit 320 per s data to earbuds (just noticable softer by 16%) made adjustment
Still softer and my is updated le
i using tidal after for 990/660
Ahhhh ok, is 990/660 stable over ldac? Or must use ldac "best effort"?
twinbaby
Hi there is he recommended to get a separate microphone which is Bluetooth based? When I at meeting in the office right, the participants can barely hear what I'm trying to say, because there's a lot of background noise, if not if there's a headphone that can achieve such a purpose do let me know
caterham7
Wired typically still better for mic quality. I use value-for-money apple usb-c earpods $24 for teams/zoom calls
You can listen to microphone quality below
artemov
Just received my AZ80.
I can't seem to make the LDAC 990 setting in Developer Options persists. Every time I reconnect, it will default back to "Best Effort".
DigDub
It will always drop back to best effort. I think only Sony Xperia phones got the option to force it to 990. Else I read somewhere can install some Sony music center app to force it to 990. But note 990 has frequent drop outs if in electrically noisy place.
artemov
Ok I did a adb logcat of my mobile while playing on LDAC Best Effort, it seems that it might be using 990 (not 100% sure though).
The important bit (I reckon!)
09-18 14:57:10.975 14924 14988 I bt_stack: [INFO:a2dp_encoding_aidl.cc(353)] a2dp_get_selected_hal_codec_config: CodecConfiguration=CodecConfiguration{codecType: LDAC, encodedAudioBitrate: 990000, peerMtu: 883, isScmstEnabled: false, config: CodecSpecific{ldacConfig: LdacConfiguration{sampleRateHz: 96000, channelMode: STEREO, qualityIndex: ABR, bitsPerSample: 32}}}
09-18 14:57:10.975 14924 14988 I bt_stack: [INFO:codec_status_aidl.cc(657)] IsCodecOffloadingEnabled: software codec=CodecConfiguration{codecType: LDAC, encodedAudioBitrate: 990000, peerMtu: 883, isScmstEnabled: false, config: CodecSpecific{ldacConfig: LdacConfiguration{sampleRateHz: 96000, channelMode: STEREO, qualityIndex: ABR, bitsPerSample: 32}}}
MangoCAT
660 is damm good le. You can listen to 2x mp3 recording quality?
artemov
I'm using adaptive bit rate (best effort), so I guess the connection quality changes on the fly depending on the connection strength.
Not sure what you mean by 2x mp3 recording quality.
MangoCAT
high kbps mean you transmit more data/s and prevent the decaying of piano g note
Henabi
you can consider getting those bluetooth single-sided Earpiece such as Jabra Talk 15 which is built for talking
veltix
Hi I'm looking for best budget earbuds, good audio and good mic for calls. Price 50 to 100++(120-130)
