MangoCAT
Currently using QCY HT05, while it's good, I hate how I can't tell when the charging case is charged until today while in the bus, my earbuds totally ran out of battery :mad: Currently thinking about Baseus MA10 for the budget, are there any others I can consider since I'm not paying too much for one.
If you are looking for brand that does sound only
Got edifier buds also. If not, got AKG n400
Got moondrop space travel also
MangoCAT
I'll check those up! I do like those with good ANC.
Generally got big brand anc and chifi anc. For most chifi, anc still catching up but for their budget range, their anc is worth le. Moondrop anc = ??
masashi
Sadly the price range is way over what I can afford at the moment. Just gave my mum my used pixel buds pro since her airpods seems to be spoilt. I ended up getting the Baseus MA10 for under $30. May just pass my HT05 to my dad.:o
oddbasket
Edifier x5 pro for $31 under lazada deals with coins
MangoCAT
The excel just to show the difference in ANC for chifi and bigger brands nia.
Space travel is 34 and got anc but dunnoe how strong
It helps in a very long run to buy tws eartips for a better seal (not those foam de or those with foam beneath silicon )
masashi
Sounds like good advice to take note :s34:
-Synchronicity-
Just checking if there are any which are 120 or less with good call quality especially for teams/zoom meetings? Previously was using Sennheiser CX Plus True Wireless but one side no longer have sound.
MangoCAT
Can consider oneplus buds 2 pro/3 for call alone. The aaron x loud rate it pretty high up since it's inside his top 5-7 list.
Most of the consensus for the sound quality 2 Pro =/ slight < 3 Pro with the 3 pro being more clearer/less bass distortion
Codec i not sure
Usually stem style will have clearer mic cos nearer to mouth
-Synchronicity-
Codec i not sure
Thank you, will take a look at OnePlus buds. Will also take a look at aarron x loud.
jokerpoker81
sibeiTrolled
My bias is towards Jabra for call quality but of course, it would be better if you can find a shop that offers physical testing
Alternatively, you can check out Aaron X Loud youtube channel
artemov
DigDub
Just bought this. Not sure what the "e" means though.
Are the settings made using the Technics app saved on the earbuds?
Meaning, will my settings persist if I pair and use them with another phone without installing the app?
Cheers! Hope the hype is real! 😅
Yes the settings are saved on the earbuds.
MangoCAT
Is not as loud on spotify cos 320 codec
My samsung 1 pro still 30% louder but realise i blasting my ears
So lie to myself softer is a feature but the quieter is better
artemov
What's 320 codec?
I thought there's a firmware update that fixed the low volume issue (with ldac?)?
MangoCAT
What's 320 codec?
as in spotify only transmit 320 per s data to earbuds (just noticable softer by 16%) made adjustment
Still softer and my is updated le
i using tidal after for 990/660
