Snoweagle
Bragi is $508, E8 is $380, 7s around $470. All 3 i have. Nuarl never owned.
Bragi dash pro- Full feature with sport function, waterproof, can swim, 4gb build in. Excellent sound. No video/sound delay. Good fit with sleeve. Very comfortable.
E8- Excellent sound. No video/sound delay. However left and right sound will shift. Needs to reset. Fit is painful for me after 1 hour.
7s- Excellent sound. Short battery life. Video and sound delay too much. No value for money.
I have the E8 and I disagree about the sound shifting as since 15 March bought until now, I’ve not encountered any sound-shifting between the buds, both have constant balanced sounds.
The sound-shifting is instead very evident on the Earin M-1, hence I’ve retired it.
kazuki666
I was looking at the regular few local platforms like lazada, qoo10, and shopee. All don't have leh. What's the price like?
Sent from Xiaomi REDMI NOTE 4 using GAGT
ralliart12
May I know where you tried the Bragi?
You can try the kiosk at the atrium of Millenia Walk. They have this makeshift store where the various kickstarter projects are physically available for testing.
I tested a Dash Pro there previously.
Dhitto
The store on the 2nd floor is called "We The People" I believe. Walked passed it 2 weeks ago.
Gadgetfreakloh
My E8 was the Dec batch one. It will shift when the Bluetooth signal is interrupted in a open area. My experience so far.
Jeremy1
Thanks, will go and test out.
Jeremy1
Listening to my Nuarl for the past 2 days and loving it.
But I would like to get a better 3rd party ear tip for better isolation if there is in the market......................:s8:
Maybe go down to Stereo and take a look.
bromprides
Using Nuarl too. So far so good. Connection is stable, no lags on videos
Can't really commend on Bragi caused I never tried before. Not really sure where you can try this earphone.
I think it's really depend also on your budget. Bragi should be around 400 plus.
E8 around 400, Erato Apollo 7s around 350. Nuarl is 190.
When trying, very important to get a good seal.
Jeremy1
Nothing to say about the sound. Excellent !!!
But looking for a better tip for better isolation. Maybe I am used to my custom iem isolation.
For the lag in video, there is definitely if u see they speak and the sound is not tally.
Connection wise, got cut off but very fast will connect back so not really an issue. Only 1 time it disconnect when I was at home about 4m away.
qwertified
Tried Nuarl NT01 today at stereo westgate branch (yay~), pretty good sound for the price, connection seems good too. Too bad the fit a bit off for me esp right side. Bass also a bit lacking for my taste, but that's probably part of the fit issue.
I read online the nozzle type can change? So the default one at stereo is not deep nozzle type? If so i can give it another chance.. maybe change the tip too the medium size look like small sia.
