Snoweagle
Anyone can enlighten me on what is meant by sound shifting?
Sent from Samsung SM-N950F using GAGT
Meaning sound played out can ‘move’ to left or right side and back. This causes more sound to be played on one side, while lesser on the other.
Jason8811
Tried Nuarl NT01 today at stereo westgate branch (yay~), pretty good sound for the price, connection seems good too. Too bad the fit a bit off for me esp right side. Bass also a bit lacking for my taste, but that's probably part of the fit issue.
I read online the nozzle type can change? So the default one at stereo is not deep nozzle type? If so i can give it another chance.. maybe change the tip too the medium size look like small sia.
I find that the large size fits better for me although I usually use medium ear tips for my other earphones.
qwertified
E8 left right unbalance when bt interrupt is known issue. my first set has it, once it shifted cant revert, had to exchange for a new one w ban leong. My current set also have the same prob but it can recover so i dont bother to exchange again. I dont use it outside often though mostly at home or in office where i dont move around much and less interference.
bromprides
Nothing to say about the sound. Excellent !!!
But looking for a better tip for better isolation. Maybe I am used to my custom iem isolation.
For the lag in video, there is definitely if u see they speak and the sound is not tally.
Connection wise, got cut off but very fast will connect back so not really an issue. Only 1 time it disconnect when I was at home about 4m away.
4m confirm d/c.
Certain videos will lag for me..
LegendZenify
Purchased Nuarl NT01.
SQ is decently good,
Intend to use for runs/in place of my K10/Zeus for days where I'm too lazy to lug a DAP around =D
Synchron
I have a question for you guys.For those having video audio lag issues with BT 5.0 Earphones, are your phone with BT 5.0 or below version ?
By right if your phone with 5.0 bt then it shouldn't have the issue mah
wizardmao
Mine is wireless earbuds 4.x whereas phone 5.0
Using E8 with Google Pixel 2 XL.
No audio & video lag.
Synchron
I read that some of the 4.x bt with improved versions can also work without video audio lag. But since bt 5.0 is a major improvement then I rather get cheap 5.0 earphone
