Henabi
Actually there is another way, many IEM especially from KZ are all using detachable cables QDC and now KZ they also sell Wireless BT to adapt those IEM of your choice into a wireless earphone. That way you can choose which IEM you preferred.
KZ AZ10 Bluetooth V5.2 aptX/TWS + Earbuds Hook with Mic Support/50 Hours Playback and APP Control for Standard 0.75/0.78mm 2PIN Connector
I think there is another newer model AZ15 but not on Amazon, I saw it on Shopee.
Wow! That's an awesome ecosystem there!
messi7
Hi guys,
my liberty 3 pro battery life getting cui after using for 1 year plus
Any recommendation on wireless earbud that has sound quality similar to L3P? Thank you
DriftKing
Can consider jabra elite 10 with offer sometime $150
I listen the jabra elite 10 have weird processing sound.
Just bought earfun airpro 4 to try. Compared with fiio t1 lite the sound is much softer, seems to loose Abit of airyness than the fiio with YouTube videos. Bass for the earfun much stronger, I think this is it's strong suit for those like bass.
Lustgan
Heard can even biost the bass using app
BlackWing1977
If you are not that stringent on the requirements of the function of the TWS earphone, you could consider picking a decent IEM + Wireless adapter to convert it.. I think that way you get better sound and future replacement made possible for the fact it is modular setup.
Lustgan
I got iem any recommendation for bluetooth adaptor? Budget max 20-30
BlackWing1977
KZ AZ09 is around that price range on shopee. But make sure your IEM uses this QDC connector.
Just note that I do not have these, just that I saw this while shopping for my IEM on shopee...
