Lustgan
Promo price I will said worth , problem is that you might not get the result you u wan for like example galaxy buds 2 u pass to every body ppl will describe it in similar matter
While Denon is purely dependent on it eq result and every result might be different
so far my eq result is pretty consistent but the sound u hear base on my result might be very different to yours and which one u like is totally another thing as it might not eq it to the way you like it
you may like your friend eq profile instead
Be warn for example it anc is still like early gen anc damm weak
btw hows the battery life? i heard last 4 to 5 hour?
rarenick
My creative zen air 2 sent for RMA. I ordered edifier x5 pro around $28. Hope it's good.
rerear
Can ask here for recommendations for those outside-ear hanging type phones 50-100? Trying to get a pair for sports, supposedly more stable than earbuds.
zzprincess
I sent in my creative zen airdots for repair. Only less than 6 months of usage. The earbuds leak charge, lose power very fast. Then cannot charge up anymore. Quite disappointed with it. I thought the local brand supposed to be of good reasonable quality.
Lustgan
Can consider creative sxfi
Lustgan
I recommend soundcore or earfun too.
DigDub
Pi8. Using on my Sharp phone with bluetooth 5.4 and supports snapdragon sound. Wonderful detail and resolution without harsh highs or sibilance. Bass is a bit too warm for my taste, turning down the bass in the app's EQ fixed that. Soundstage front and up down is wide, left right is slightly wide.
Lustgan
How much u bought i saw price quite steep
