Jeremy1
Who here got try the Noble Audio FoKus Rex5 True Wireless Earbuds ?
What's your opinion as compared to the Gemini 2 ?
Gadgetfreakloh
I got it. Excellent sound out of the box. Gemini 2 has very good sub bass. Rex 5 are balanced until you play with the personal eq. Personal eq can tweak the sound to your hearing.
The sound adjustment are infinite. You can adjust any sound profile. This is the most versatile and adjustable tws I have.
Overall this has the most details and very smooth audio.
I just leave it at default sound settings. Excellent.
DigDub
Bought a Samsung s25 phone recently, got the buds 3 pro to take advantage of the higher bitrate offered in the Samsung ecosystem.
ANC is pretty good, just very slightly below Bose and airpods. Treble is a bit hot due to the Harman tuning, turning down the 8k band in the wearable eq by a notch makes the sound more pleasant. Soundstage is quite three dimensional and enveloping. Bass sounds textured and powerful when called for. Mids and highs are crystal clear. The timbre sounds a tad off, maybe due to the use of a planar driver for the highs and mids.
The controls are on the back side of the stem, opposite from airpods, so controls are controlled by the thumb and not the index finger like airpods. The case is very pretty with the transparent top flip cover.
Nakedtoes
Just recieved the Denon PerL Pro.. I am really Wowed by the SQ after AAT.. However the right earbud cut off after a while when Spatial Audio is disabled is the killer factor. Searched the web and mention disable Bluetooth scanning etc,, tried many settings etc and still can't solve the issue. Spatial audio enabled do make some music sound spacious etc but it mess up more then sounding right.. So going to return the earbud.. What a waste..
Nakedtoes
Just recieved the earfun pro 4.. For the price of 70.. I dun think any other TWS can beat it.. The built quality is very good especially for the case. Buy to try the different codec LDAC vs Aptx loselss. Overall this TWS sound surprisingly good if u get a good seal. The instruments seperation quite impressive.. Sound is abit towards the dark type. U CaN play with EQ to get the correct sound. They got the sound test to test yr hearing and do yr personal EQ
.. Dun like the result .. Overall prefer Aptx lose less vs LDAC
. LDAC has good details and better resolution however aptx loseless got a more dynamic sound and slightly more spacious sound..
Very rare to have tws with both excellent top codec to try...
hectic13
How do you get the $70 offer for earfun pro 4 on lazada. It’s always priced above $100.
wishyq
Hi friends, looking for ear bud recommendation after my 4- 5years momentum tw2 case gone missing.
I am a Android user, so can't enjoy the apple ecosystem
Specification I am hoping to have
1.Water resistant and good fitting(can go gym. If can using for jogging (means good fit, better)
2.good ANC
3. Durability - saw some post long time ago mentioning bose QC Earbud spoil after 1year plus, hence go for Sennheiser instead. Not sure how is it now, the fin sure looks good.
4. Sound - not really an audiophiles, so not sure how to adjust equaliser on my tw2, hoping that the default setting is good enough.
Thank you for any recommendation ☺️
Lustgan
2.good ANC
Eatfun air pro 4 solid
Lustgan
U buy from amazon uh…
