DigDub
The Technics az100 are here. Initial impressions are that the sound signature has a heavy mid bass with mellow highs. Az80 has a wider soundstage, probably due to its acoustic chamber, which I believe the az100 do not have. The tips are proprietary with 2 protrusions which fit into the 2 notches on the earbuds nozzle. ANC is pretty good, no wind noise. Wearing comfort is good, the earbuds body are quite slippery. The app has many options to set the controls, ANC options and ability to set 3 custom EQ settings.
Size comparison between pi8, az100, az80 and wf-xm5.
Jeremy1
Can win my Gemini II or not 😗
DigDub
How rhe sound quality tho compared to az80…. I see az80 discount since az100 released edi
Az80 sounds more dynamic (Harman curve) than az100. Az100 has a more mature tuning with warm sound signature. The cons of az80 is its short battery life of 4.5hrs if using with ldac, so if that's ok for you, az80 is good also.
xonix
Moondrop Block vs Soundpeats Air 5 Lite. Which should i get if both are around the same price ? For use on Pixel 8 ( read that AAC implementation is bad on android )
