otacon
No good discount for soundcore liberty 4 NC, $55 now
Anyone saw any good discounts?
dev_stg_prd
dev_stg_prd
Yeah heard from others said adaptive is lossless also.. But I try ldac at 990 not turning back.. Infact this using BT5.4 the connection at so high resolution still very stable even when I place phone on living room and go kitchen toilet.. Other BT at 990 sure drop connection
what is 990
jokerpoker81
still considering long long time for soundpeats air 5 pro on taobao, about $72 ? all in. 4 pro no more stock for the transparent version. anyone seen better prices any sites?
luei74
Can check if there's an cordless IEM? Wanna try out if there's a BT version for IEM
TheOutsider
NOT A RECOMMENDATION
But I came across something like this online so just sharing: -
2 x BA driver each side, zero idea how it performs
https://www.lazada.sg//products/i2609699274-s16577117607.html
Or something like this to convert compatible IEM from the same brand into earhook style TWS they got few versions different spec/compatibility you can look up more in their store
https://www.lazada.sg/products/pdp-i2611570627.html
https://www.lazada.sg/products/pdp-i3507520410-s23161381594.html
https://www.lazada.sg/products/pdp-i3062967553.html
You got to read up and decide for yourself if you gonna buy. I just somehow came across this and came across your post so just for sharing.
luei74
Thanks, I will try to find at Taobao.
Asure7
should be able to get about $65 or at least just below $70 on Lazada.
Saw it once below $65 but should be during sale with coins. maybe have to wait for 11.11
TheOutsider
at half the price, the buds from soundcore, baseus, earfun are better .
At almost 1/4 the price, my mum complain my soundcore Liberty 4NC (bought for ~$45) mic sounded worse than Baseus BC1 (bought for $12.8) that I bought to try out how ear clips work for me.
Not recommendation but for $12.8 (after some shopee vouchers on 10.25), really nothing to complain. Good first try on earclips style buds. Sometimes really forget it's on my ears. $12.8 with app support, customization, equalizer, multipoint (2 devices) and 24 months warranty.
storm913
May I know how much was it before the vouchers? Waiting for 11.11 sale as its $30.90 before voucher now.
