Wireless IP Camera thread
pank
Hi, are there any non-cloud based IP camera? Not sure if "non-cloud" is the correct term, but I'm looking for a IP Cam which can connect directly to static IP to view rather than connecting to cloud server. TIA.
localITguy
Suspended
many ip cams does that.
all recordings are stored on the SD Card itself. you can view the recordings to going to the IPcam's camara IP
Just to name a few
Foscam
Sineoji
DLink
be sure to check on the box before you buy
pank
Just to name a few
Foscam
Sineoji
DLink
Thks for the info.
Just to clarify, does it mean that when I use the mobile phone to view the live video, it is connecting directly to the camera and not connecting to cloud server?
Shasha_Zac
Hi,
I would like to say a big thank you to Dean for helping me with the installation. Bought 2 PT603 ip cameras. This is my second purchase. Dean came last Saturday on 11 June to deliver and install the new ip cameras. Wanted to check if I am able to view all the 5 ip cameras using the app on my mobile phone but it seems that my previous buy(both my PT495V) kept disconnecting. Dean helped to update the software and kept on trying for so long. He was at my place almost 3 hours, still figuring out how to help me with the Wifi connection issue I was facing. After so many attempt, my cameras still could not work smoothly. I felt really sorry to those who waited for Dean or tried reaching him while he was busy troubleshooting at my place. In the end, Dean had to make a second trip on Sunday to help me look into the issue. After all the struggle, he managed to assist me resolve the connection issue. Despite my complicated wifi connection issue,all my 5 ip cameras are working well now. Tried the new PT603V.. one of it had a tilting problem and he had it replaced instantly. My apologies Dean, you were late for other customers apppointment. But you still go all the way to assist me. Thank you for rendering a good service. I am happy with the product and service by Sineoji.
batniss
Thks for the info.
that depends on the setup.
Most cam allows either or both
okinawakyo
I have 2 old model Vstarcam IP Cam. Last week out of sudden, these 2 seems like got problem. The camera keep on rotating and then will stop a default location.
Even i call the preset, few minutes later, it will rotate again and go back to default location.
Emailed the distributor but telling is EOL, so no support.
Any advice?
Thanks.
batniss
Any advice?
Thanks.
get new ones and skip VSTARCAM.
geckoSG
Any advice?
Thanks.
If you have a keep rotating situation, i remember is that it is due to connectivity issue, the camera cannot get internet connection. U try restart your router and then your camera and see, if cannot, i bet their DDNS or cloud server is down already.
Too old better change, the recent test of cameras I had fun with are not bad, 960P range from MARIX is not bad for novice, it lacks webui though, got demo online already. Supports AP mode if you do not have wifi. Yesterday they upload new pricing, very competitive. Else, we have the upcoming 1080P PT619V from Sineoji too (OEM of HW0048 by wanscam with 1080P)
geckoSG
wow? where you get this info from ?
Read the post from the previous guy who created a big response from the marketing crowd. Think of it, if wanscam launched a product way before Sineoji (in form of 720P), do you think Sineoji would have owned the shell design initially? However, I am super duper curious how he got a 1080P set when the last I managed to get is only a 960P unit in china when I visit there (true 1280x960P onvif streaming)...
Do a comparison of all of wanscam product and Sineoji's product, in terms of shell, you will be able to tell where the source is from, check out also the mobile APP interface against wanscam and Sineoji. No offence, even for MARIX's products, they are from China too. The only products maybe I would place my bet on own R&D is Samsung & D-Link, but not everything.
I traced the Zafego also, though it is a collaboration with the Swedish, it is also an OEM from China too. Its just local branding done for China made products via the west. It proves that China products are gaining acceptance from the world due to pricing.
Unless the companies can prove that they own the design patents with certs, otherwise, high chances is, its an OEM from somewhere.
batniss
no hard offence, the previous guy sounded dubious. Believing in him is like... to think that only you among the rest believed him.
Strange enough, the guy and you were both singing the same tune.
then again to be honest, OEM or not if the service is there, is there. People will know which is good for them and which isn't.
goodwin
Reading this remark, you using Sineoji's brand name to market your hw0048 OEM ? Legally speaking I don't think is right.
If you are selling Sineoji's cams, perfectly fine. But if you are not selling Sineoji's cams and portraiting your OEM hw0048 as sineoji's cams, it is unethical as some consumers might assume is sineoji where is not, so as to speak.
Most of us chose sineoji is because of their excellence where it comes to support and their cameras are as good. One ring, they go to the extent to even do repeated house visits for support where they don't charge at all. Dedicated and passionate that's what I described. Others will charge $80 per visit, subsequent another visit $80, cash cow.
Thumbs down to you.
localITguy
Suspended
Thumbs down to you.
what you expect from someone who says the grape is sour when they can't have them?:s13::s13:
geckoSG
You mean among the aggressive marketing accounts? Maybe you can also do some online research on the IP camera market and you will know the truth, google the information on both brands, look at the model and you can know, compare the APPs. Have you done comparison? Make sense? Or still in "denial like the others"?
But, the guy who posted the review, I seriously doubt he have a 1080P unit unless he proves it, as far as I know of, it is max 960P that they (wanscam) have in their product range for consumer pan/tilt.
In terms of services, currently both companies (Sineoji & Marix) have very good reputation in the market, this fact I shall not dispute for sure.
geckoSG
Thumbs down to you.
You are just taking a sentence out from a paragraph. I talk about the options from MARIX and SINEOJI, which latter have a quote to reference the SHELL MODEL from wanscam
Read again.
I have never denied Sineoji's services.
batniss
Denial like the others?
Is your credibility and the ability to distort your motion drives everyone to have that conclusion.
Marix, marix, marix. Your hidden agenda is already pretty obvious don't you think?
Is it me or others are also sharing the same thought that that person is actually you in disguise? Because so far it seems like you are the only 1 trying to whack Sineoji for Marix. No one else does that except those newly created accounts / low post count accounts
No offense but you can continue to indulge in your little puny comparisons where the mass continue to get what they believe is the truth and good for them.
localITguy
Suspended
cheapitservice you mean?
desatans
looks like we have a clone here :s8: just to bring down sineoji?
anyway, what's with this hw0048 OEm and sineoji? Not sure how many people care out there. But personally for me, like most users here, I just want a decent quality, simple to setup and user friendly ipcam with reasonable pricing.
I started out with vstarcam, then to zafego. After i read reviews posted by gecko. Both of them purchased from Marix. Price wise, I would say quite reasonable. But then, it feels like "buy-and-forget" type of transaction. Response to issues and questions were slow, some unanswered. Until i stopped contacting them. However, that was before sineoji became more and more popular with users here. Nowadays, more competitive. Can even see them offering free delivery and installation?
When sineoji came, I was hesitant to try becos of the pricing. I contacted Dean thru pm and his response was fast. He offered a no obligation 2 weeks trial. Any other brands offer this?
When I missed the promotion period and wanted to purchase the ipcam from him, he offered me the promo pricing. Scheduling the installation date was a breeze as he was easily contactable. When he came down to install the ipcams, he was professional. Making sure we knew the process and went thru the setup on our mobile, checking the 4g/wifi response of the ipcam, setting up on your pc or laptop. I read he drilled holes, installed trunkings and even setup ddns for some users too. Any other brands offer this?
Even after the job was done, when i threw him a few questions now and then, he will get back to me very responsively. Sometimes he still whatsapp and checked with me how's my room wifi issue. When there's a new firmware update, he notified and asked when i will be available for the update. When one of my ipcam got red tint issue, he offered an exchange. Before 597V was launched, he offered me a sample to exchange my older 593V for testing and keep FOC. For all the above, could other brands offer them?
Most user of sineoji here may have their own different experiences with Dean but one thing is for sure. The services and response from him. Which made me confident to use their ipcam even it was some oem!@#$.
So do you think I care?;)
