Wireless IP Camera thread
localITguy
Suspended
hi. I just bought the PT713V. One key keeps telling me search failed. restarted everything including my router. Please help. TIA.
connect the cam to ur router directly via LAN cable and do a lan search.
add the device and configure the wifi once added. after that change the password of the cam and disconnect the LAN Cable.
hiton
Saw that most will use sineoji .
Anyone used xiaoyi?
Any comparison for these 2?
earthlink
Anyone used xiaoyi?
sineoji cam viewing on live feeds such using your mobile 4G data is super fast, real-time. If you pan, the cam moves instantly with no lag.
When I was in Brisbane, remotely view the cam residing in Singapore, is so responsive, real-time.
drifting
Hi all
I need to install 3 cameras at home. Mainly to monitor maid suspicious activity. Read that sineoji is a good brand and value for money. Can I ask whom I can contact for purchase and installation please? Thanks in advance!
hiton
Ok will look for sineoji
Thanks for the feedback
Dave27
Totally agree.
Dave27
Hi all
Just browse from their website, go to their online store and order.
duckling
Bought the Sineoji PT713V from Challenger yesterday...able to hook up via LAN cable but not via wireless, I'm using Asus RT-AC68U 2.4Ghz.
goodwin
First, power up your cam, without any lan cable attached to the cam, you must hear a continuous alarm. If you don't hear that, reset the cam by inserting a pin at the base of the cam where the reset hole is, press it until you hear a music, release the pin. Cam will restart, and wait for the continuous alarm .
Have your android or iPhone connected to your wifi using the 2.4 band, not the 5G.
Next open the sineoji app.
Hit the + icon
Tap on the one key
Enter your wifi password ( check the said shown there is the 2.4 band)
Click start
After 60s, the camera ID is shown
Tap on the camera ID and enter the default cam password.
Click Save.
duckling
Hit the + icon
Tap on the one key
Click start
Click Save.
Thank you very much...it works!
jason
Anyone deployed IP Camera at your aircon ledge which is outside your house ?
Any idea how to do it legally ?
localITguy
Suspended
LOL.
unless someone kaypoh go report
you want law by law. go apply for a permit with SPF/HDB
and why u want to put at that location?
anyway, thie cams are not water-resistant, so if wet spoil not covered under warranty, you might want to cling wrap it or something
jason
LOL.
Yes. Law by Law. Snr Inspector said the same thing. Apply the permit from NEA and HPB. It is for high rise littering.
Cause upstairs throw rubblish into my living room ledge and aircon ledge.
So need a IP Cam to capture them red handed.
Understand most of the IP cam is not water resistant, that's why asking the Guru here.
