Many Thanks but how do I change the password and which one to change?
On the main page of the sineoji app, select the i symbol.
Go to user
Under admin, change the password. Do the same for operator and observer or guest.
Then click on save.
Go to user
Then click on save.
Is the promotion still valid for the free mounting and installation from Sineoji ?
Contemplating between the PT603 and PT713.
Noob question. Do I still need router that support ddns for accessing sineoji cam remotely from mobile phone?
Or does the camera have some ddns client that can communicate automatically with the sineoji app for remote access?
I used to have to set ddns for my old dlink camera.
You don't need any ddns nor port forwarding on your router.
Have your phone connected to your wifi, make sure you select the 2.4 band first.
Download the sineoji app from the app store.
Open up the app
Hit the + symbol
One key
Enter your wifi password
Hit Start
After 60 seconds, it detects your CAM with the cam ID
Select the cam ID
Enter the default password of cam as admin
Hit save
That's it.
Thanks. So seems like the camera is communicating with some private sineoji server and authentic and access is via their server.
I believe Panasonic used to have similar features.
Concern is would sineoji make it a paid service for remote access.
It will continue to record I'm using Synology
For those who are interested to buy Sineoji should just buy thru their e-store
- they will help you link to your wifi
- they will recommend the place to install your cam
- trunking will be done (a surprise for me)
U will have to do all these on your own if you get it from the stores yourself. So far happy with the product and the great service by dean
am using the sineoji cams too, live video is really fast using my phone's data, as good as viewing from home wifi network.![]()
When u say sleep u don't mean turn off right? If so No. If there's low activities e fan slow down but my NAS will always stores e images all my cameras are putting.
Yes my NAS is powered on all time if there's no activities it'll go into hibernation mode. However when there's a file transfer it'll wake e NAS. Hence to answer e previous question if e NAS is on sleep mode will it store footages that was recorded by e camera. Answer is Yes, because each time u FTP or NFS to e NAS it'll wake e NAS despite in hibernate/sleep mode.
As the NAS May take sometime maybe like 20 seconds or so to wake up from hibernation, I’m concerned there will be like 20 seconds of footage gone, which may be critical in some cases, like some one tries to destroy your camera and didn’t manage to capture the fellow face
some camera like the d-link will append footage to the front of the recording.
i.e 10s before and after the motion started.
