Wireless IP Camera thread
Devilsire
The magnetic version unable to support NAS? and its the only cam supporting wideangle 170° version
eauyong
Since you mention 170°, I got the idea of putting two cameras back to back and will get 340°, it is almost the total view of panoramic 360° (less only 20°) no need to PTZ. Any comments?
AcEz874
I received my Xiaomi 360 1080p camera already! the setup is walk in the park haha! i really like the camera and the App :) a good camera must have a good app and support!! very important.
AcEz874
Just to double check with everyone here, the Xiaomi 360 IP Cam able to hold up to 32gb or 64gb memory slot? when i was configuring the playback for memory card, it says my device only able to support up to 32gb but xiaomi official site stated 64gb, is it the app didn't update the microSD card info?
Soccer Ball
Suspended
64gb no issue
Giddeeyore
I use ipcam (port forwarding) on days when sineoji apps is not working well
But the sineoji new model doesn’t seem to support ip forwarding. Looking for other brand/model also but can’t seem to find any .....
Hi,
I'm using the sineoji PT716V ip cameras and encountered similar issues too. I'm on Starhub BB and can't access the IP cameras when I'm outside [which kind of defeats the purpose]. Only encounter issues in the recent months.
Just to check is the only solution using port forwarding? If so, which app on the IOS supports this?
Thanks in advance to anyone who can recommend. :)
Hot2002
Hi,
ip cam viewer
midlusionz
Hi,
get a free ddns from no-ip for your router.
Giddeeyore
ip cam viewer
Thank you! I managed to get it up and running based on your recommendations.
But I guess if you want to secure the ddns (e.g. using https) need to pay right?
A bit disappointed with this Sineoji. Initially bought it avoid all the hassle of port forwarding.
I wonder if this encrypted IP affected only Sineoji IP cam or other brands as well.
Regards
testerjp
Is there any set up that works with a Mifi using sim card?
I'm worried about the bandwidth used.
Record only when there's movement and store the rest on SD card?
I've a warehouse without internet connection and business internet lines are too expensive
eauyong
The easiest way is to get a 4G router and a Xiaomi models that use IMILAB Mi camera PC client software display on a 32" 1080p TV upto a max of 9 cameras simultaneously or zoom in to any one camera. Recording by motion detection or 24/7 recordings onto 64GB microsd. Motion detection AI tech by Xiaomi is very advance and can detect even an insect movement across the lens. Notification of detection will be recorded onto Xiaomi servers (kept for a period and then deleted) and notify to mobile phones simultaneously but with a few cameras, you will be very busy. ;)
testerjp
So it records locally in the SD card.
Only send notifications to Xiaomi server and my hp.
I can connect remotely and access the cameras if required?
