Wireless IP Camera thread
geckoSG
Like what VSTARCAM claimed and per GeckoSg, it is easy to set up H6837WIP ( plug and play ), but port forwarding still need to be done on 2wire 5012nv for viewing over 3G on above phones and tablets.
Cheers!
You mean you watch on mobile not using the P2PCAM264 application? If P2PCAM264, there is no need for any port forwarding at all.
geckoSG
Can you kindly recommend any android app that will work with our S2 for H6837WIP for audio / speaking & PTZ function? for the IP Cam viewer Pro by Robert Chou, do you know the settings that you can share with me?
IP Camera Viewer Pro only can let u do everything but no sound. MARIX still trying to get them to work on the sound.
host/ipaddress is in format of serialno.dns.gocam.so.
koh0222
Guys, i looking for wireless ip cam with 24hr video recording.
Can recommend me some models?
Btw, what is NAS?
tidus792
Can I just ask about the H6837WI wireless function?
I'm unable to get the camera to connect to my router. I suspect it's due to my wpa key being max length with all asci characters. Does anyone else have a super complicated WPA key and have difficultly joining the network wirelessly?
geckoSG
Upgrade your firmware to the latest, the limitation (bug) on the WPA key (64 character) was resolved in the latest firmwares.
geckoSG
Btw, what is NAS?
H6837WIP, record to its 32GB MicroSD card on local IP Camera, playback via its webUI.
NAS = Network Attached Storage
vampire5
Hi Geckosg
Ok thanks for the reply. I have not been able to view H6837WIP from mobile browser. Do you know if any ip cam which s capable of doing that. So far my webcam XP program on computer is capable of being accessed on ipad, android , ie and firefox browser. Powerful but must keep computer on ,all the time..
Lordzephyr9
Guys, any comment on this ip cam?
$79 for 1, $159 for 2, $299 for 4.
Image sensor: 1/5" Colour CMOS Sensor
Display: 640 x 480 (300 pixels)
Lens: F: 3.6mm, F: 2.4 (IR Lens)
Microphone: Audio 2 way
Server: MSN server/DDNS server
Image compression: M-JPEG
Image frame rate: 15fps (VGA), 30fps (QVGA)
Resolution: 640 x 480 (VGA), 320 x 240 (QVGA)
Mobile phone monitor: Support iPhone/iPad/3G Phone/Smartphone
Pan/tilt angle: Horizontal 270degrees, vertical 120 degrees
Infrared light: 10 IR LEDs, Night visibility up to 15 metres
Product size: 100(L) x 100(W) x 125(H)mm
Packaging size: 196 x 165 x 123mm
Net weight: 254.7g/pc
Power specification: DC 5V/2.5A *1.8meter
Power consumption: 5 watts
PC requirements:
- CPU 2.0GHZ or above (suggested 3.0GHZ)
- Memory size 512MB or above (suggested 1.0GHZ)
- Display card 64M or above
- Supported OS: Microsoft Windows XP/Vista/Windows 7
- Browser: IE6.0, IE7.0, IE8.0, firefox2.0, firefox3.0, Google
1 year*local agent warranty (see Fine Print for more details)
geckoSG
Hi Geckosg
Something I really cannot understand, there is a P2PCAM264 application, why do you still want to view via mobile browser at such? What mobile device are you using?
If you want to see non-LIVE Streaming, you can actually download their VStarcam Video Surveillance System and add your camera to it and view.
The safari viewing is possible too, you just need to do port forwarding on your router if you want to view via web browser on mobile. Its the same for all the IP Cameras.
Lordzephyr9
Hi Guys, Am looking for ip cams that allows 24/7 view and recording.
Which model is highly recommended?
daohuay
how much did you pay? is the image quality good? is 64GB sd card enough for 24hours recording?
I brought it @$218 with doorstep delivery. It's a 720p camera H.264 compression. Image quality is acceptable for mobile device, but its better on ur PC browser.
As for the sd card, i'm using 32GB. Its should be enough for 2 or 3 days I deem.
geckoSG
bro, I think you meant http://youripcamera:rstpport/h264 I tried can't get it to work. Your's can?
You are right on the URL. Thanks!
I used to be able to see it, can't remember which firmware. Now I am using
the H6837WIP, so I don't bother anymore on the H6837WI.
Now I guess your best bet is that MARIX finds their developer soon to develop the LIVE streaming for the H6837WI community so that sound
can be heard.
