pwillie
- Dec 17, 2000
I love Mr Porter to bits but I wouldn't buy shoes from them.
Sent from the exploded Death Star using GAGT
Likely doing a short detour to London year end
Any comments on George cleverley shoes?
Price wise they are all over the place on mrporter, so I'm guessing their benchmade and Anthony range has got quite a gap..
Thinking of getting their benchmade, but some research suggest that they oem from CJ... So the question is; are they worth the premium over CJ?
Hello. Some of us would recommend you to wear several times to season the leather to your shape before Vibram or topy.Hello.
I got myself a pair of leather soled shoes and was suggested to get a "vibram/topy sole guard" to ensure the leather will not wear and tear easily.
Any idea where i can get this "guard" made in SG?
Many thanks
Just need to find someone with my size in the Ron last and I'll be set..Looks like I'm one of the few that actually like the Ron last from meermin. It fits me well on my heels. The breaking in was a bit*h but after that it was really good. I do think the sizing should be very much the same as the new Rey. I got a half size smaller than my others n I find the length a little short.
How was it? Did u try out any shoes? Looks like he might have some sample sale sometimes. Lol
I am normally a UK 9, but went with 9.5 for the JFitz loafer based on comments in SF and Justin over email enquiries. I regretted. It is too long, and i had to put in some heel inserts (and still too long, but now wearable).
I went with UK 9 for a Carmina uetam loafer next. And that thing is tight. But I would be able to stretch that over time i guess.
I have a higher than usual instep which makes buying loafers an issue.
I don't have any other JFitz shoes and i did not make it to his Singapore trunk show also.
I get mine done at kips n kwiks (junction 8). Very friendly and good service.
Sent from Gong Wu Gong Bo from OnePlus 1 using GAGT
Different brands, and most of the time you will be limited by what the cobbler carries.Thank you for your response.
Is there much difference between a vibram or topy?
A pair of ..... ?
Baker Newman MTO Dainite sole - Black calf
He put it in his subject title. Although I believe he meant "Barker"
No prob man. Happens to the best of us. Just that I happened to pcw on my desktop.Oops ok. Cant see title on mobile view. Tks
Shukey, for example carries Topy and Masterfix, Vibram.
Bro, did you wear your shoe for few times before apply the guard? There are a lot of mix comment on this in www. Still not sure which one to follow. Would you advice based on your personal experience?
Hi,
Have purchased a pair and unfortunately last is not suitable for my feet.
Looking to let it go asap.
Do PM me if you are interested. Thanks.
Hope that I am not violating any sales rules here with this post..
Time to move on to enzo bonafe. Lots of high instep lasts.![]()
