urbanturban
- Dec 14, 2003
...after a while, you will realise that it all depends on your personal preference...
Some like it snug.
Some don't.
Some like it snug.
Some don't.
Thanks all for the recommendations!
Next qn that comes to mind is that.. I have been reading that shoes should be snug and no heel slip on initial wear.
What does "snug" mean?
Jeez thundermarch, I don't even know how you find the time to maintain and polish all your shoes, let alone finding the correct shade of saphir for each pair lol.
It's a wonderful problem to have though.
The general idea is that there shouldn't be too much room inside the shoe that causes excessive movement of the foot within the shoe.
The toebox should just touch the edges of your little toe and big toe, with just a little room for expansion as your feet splay out a bit more both at the end of the day and as you get older.
The vamp area should not be too voluminous and should also be at most an mm or so above where your toe joints are (where your toes meet your foot).
The instep should feel firm against the top surface of your foot (with just a bit of pressure) and with a 1cm gap at the top of the facings.
The waist should also feel firmly (but not uncomfortably so) pressed up against the arch of your foot.
The heel should cup your heel nicely with not too much room left and right of your heel for it to move around. When you toe off, there should also be no heel slip.
That's snug.
This is great info! Thank you.
I think many of us are used to and define comfort in our non leather / business shoes as being a bit loose, and hence transfer that to our leather shoes, which ends up being a bit looser as the foot bed sinks and the leather stretches.
On laces - how do you guys prevent the laces from twirling into a mess? I use a horizontal bar lacing method, and when I adjust my shoes the laces invariably become a twirled up mess. Hehe.
Sent from Xiaomi MI 3W using GAGT
@tm what's your experience with the 363MOD last?
Joining the EB LW GMTO?
Hard to visualize that model in Oak Tarnsjo leather.
Was very tempted by this make-up as well.
Emospence proved to be the deciding 4th member of the GMTO.
The Oak tarnsjo is incredible stuff.
Ya, been eyeing a longwing to add to my collection. it's either this or carmina's detroit longwing.
but it's 363 MOD. not sure if i can downsize to 6 UK.
6.5 UK a bit too loose for me, ended up my split toe went to a happy buyer. right, arcfire?![]()
6.5 is your normal size?
Ya, mostly. Can wear a 804 oxford in size 6 though.
I'm guessing a size 6 for 363MOD will suits me.
Try lor, if can't then sell and take the difference as tuition fee to know the last doesn't suit you at all.. Though I'm guessing should be can ba?
I'm normally 9.5, wear 9.5 too for 804 oxfords, Gabriel recommended just sticking to 9.5 for these..
Your previous split toe was too loose for you in what sense?
