All in a Day
- Jan 3, 2014
Not too bad actually...might get the Chukka to replace my current loafers. The question now is...EB first or Loake first
Haha yes, was eyeing of the double monks from Enzo but, don't know if I will bear to wear it around industrial area...Are single/double monks supposed to be slip on though? Or is the buckle/strap just very easy to remove/put on?
Any recommendations on who/where to send my beat-as-hell and overly abused shoes for polish/touch up?
1. Enzo or Loake depends on your budget and comfort level. Recall you mentioned you cannot bear to wear Carminas to industrial area and Enzo costs more than Carminas....
2. From my personal experience, monk shoes are not supposed to be "permanently" buckled and worn as slip-ons. If you could do that, chances are the fit is too loose.
3. Try shoeshine uncle PetiaC who incidentally re-surfaced last evening after a long hiatus.
