Working Shoe for Young Exec - Part 2
urbanturban
The Quarters currently is running MTO orders for Carlos Santos Patina Service Program. They have sample pairs for customers to try. If you're interested, can arrange for a fitting session with them to try out the shoes before placing order, as it's always best to try before purchasing.
Where is The Quarters' location?
nkapped
Haven’t bought this personally but if patina shoes are something you particularly want, I’d advise you to try Caulaincourt which does a very nice and better quality range. Septieme Largeur is frankly quite overpriced in Singapore. Better off buying it abroad.
No one experienced with this ?
nkapped
Hey bro, I bought the double monk in dark oak lady year. I took a half size larger in the AM Aeris Soft Square compared to my Carmina Rain size. Interestingly, the Aeris Soft Square last is slightly different from the Argentum Soft Square last. Check with Yeossal if you have further sizing queries - I found Jackson very helpful.
Any idea how's the fit for their Aeris shoes? Looking at the Double monkstrap in Burgundy. I'm a usual Carmina Rain UK7.5.
wiz
Interestingly yeossal mentioned Aeris is slightly narrow at the toe box for soft square compared to Argentum
TUV2008
What about my this patina?
Sent from Xiaomi MI MIX 2 using GAGT
thltetek
Thank you for the advice, appreciate it bro. How do you find the fit after sizing up by half from your Carmina Rain size? If only the Adelaide was going at same price as the Double Monkstrap too, then that'd be perfect.
wiz
You can buy the Adelaide then another Corno Blu at 50%
wiz
I got it from their email mailer. Bought a couple before. Just add the Adelaide into cart and you will be asked to select a Corno Blu at 50%
May I ask where do you see this sale bundle from? Only with purchase of Adelaide, then there will be 50% of its Corno Blu shoes?
