Working Shoe for Young Exec
PetiaC
I can try but I will have to send it but I guess again haha...
Total damage 35 with around a week turn around.
ok we try another way to experiment, u drip water onto the affected area, dun rub. before you put any nano protector.
if the water glide away then is painted over if the water form dark patch then more likely to be dyed.
alvinquah
Ok try that and report back
SquallLH
edetal Mountbattens
I like these boots! Damage from Ed?
Looking forward to your update :)
evilnickwong
Wah, great deal :s12: what sizes are they?
Size 45.
Oddly, of all the leather soled shoes I've worn, these were by far the most slippery when wet. Almost fell down several times when walking on rainy days. Ended up getting Continental topys installed and now they're great as wet weather boots. :D
SquallLH
Did u get ur carminas fr shop or online? Their shoes are cut beautifully but i suspect narrow
Got from ebay actually. As they are loafers, I just got them half an US size than what I normally wear. It ended up slightly long but putting in a heel guard solved the issue. Then again, Queen last isn't their narrowest last so, you might want to go with your exact or size up slightly on the width....
Size 45.
Were there other sizes when you bought it or just size 45? Yeah, good idea to get the topies for your "all weather boots" :D
PetiaC
If paint can use renovateur? Will cause paint to be removed?
Paint when dried not so easy to remove. But it is just sitting on the surface, if scratched will reveal the dark spot.
Renovatuer is not so abrasive. Avoid the harsh cleaners.
Acrylic paint can buy from art friend and match the exact tone, if the paint needs to recoat.
arcfire
Wouldn't the acrylic paint crack after some time or if the area is flexed?
alvinquah
Crack i am not too sure only time will tell. I just to flex the area that has been painted over, apparently it is still holding up well....
archangle13
Any recommendations for cleaning stinky leather insoles? Not my shoes, but I need to get rid of the smell. The insoles are non-removable.
So far, I Googled baking soda and vinegar.
SquallLH
Saphir Renovating Recolorant Repair Cream
Try this next round?
This was pretty effective for smelly sneakers, NTUC stocks them.
Sport Fresh Force :: KIWI care products
alvinquah
Is it better to topy new shoes or after you've worn them for a while?
Based on petiaC recommendation, it is better if wear a few times then topy it. The cobbler will sand it evenly before sticking topy. That way it stick better....
