Working Shoe for Young Exec
PetiaC
Went crazy skyping my friend while polishing my shoes...
... What to do with the cracks :s27:...
Will it be wise to remove all the wax and re-polish my shoes again?
Dun bother lah just wear till the wax flak off and wipe away with a soft cloth. Next time polish the creases with a light layer of a wax and brush it off, no need to waste time and effort on the part of the shoe that flexes.
patryn33
hi guys,
can any1 share what are the usual brands that they frequent for working shoes for high arch feet ppl?
my focus is on comfort and hopefully no more than $200++:s12:
Is timberland leather shoes a good brand to try for daily working use?
Many thanks in advance!
Get some insoles. Those numbers now nice ones superfeet cost like usd$40
aerolord
Thanks, I will give that a try... this two are my first two pairs of proper shoes, so pretty new to all these :D
All in a Day
hi guys,
Not a high arch guy but high arch could result in you having a higher instep so I would suggest going for derby rather than oxford dress shoes. Focus on comfort, then brands like geox, rockport, clarks and hush puppies come to my mind..
Also, I am not sure what's your occupation but timberland designs wouldn't typically make the cut for office dress shoes.
But if the shoes fit you and the design is acceptable at your workplace, why not try?
Good luck!
aerolord
I hope u apply some sort of leather conditioner or cream before u waxed them.
You mean before the first layer of wax? I think I did, I went through the whole process...
Reno -> Cream -> Wax
But I don't think now need to reno and cream that wax part anymore right? Since it is wax already..
bratpig
You....put your shoes on your....TABLE????
tty
Happy new year to all.
Need some advice from bros who've had experience in both the Loake capital and Carmina rain lasts.
From what I read, it appears that most take the same size for both lasts.
The Loake capital last in UK6.5 is a very snug fit (not uncomfortable though) for me, except for the instep area wherein I have to pretty much lace up fully (not much of a "V" if you know what I mean) in an oxford. Given the snug fit, I'm unsure if I should be getting the same size in a Carmina oxford in rain last. So I guess the question is, is the rain last somewhat wider/narrower than the capital last?
Appreciate some advice here. Thanks.
All in a Day
Rain last is very slightly narrower than capital last. If capital last is just nice for you width wise, rain would be tight. Instep wise rain is also lower.
tty
Sounds like I may have to consider sizing up by half. At least that gives me the option of using an insole in the worst scenario. Thanks bro.
tty
Hmm, come to think of it, would an Inca in the same sizing be ideal then....
All in a Day
Hmm, i dont think it requires sizing up. Not sure how snug is snug for u on the capital last. If u dont experience any toe pinching w capital last, perhaps u can take the same size in rain.
Anyway KS is carrying carmina, go try sizes for yourself will be the best option.
