Xiaomi Box Android TV Box
faded11
Use Arial font to see Chinese text in Helix/Kodi.
Cheers!
thanks a lot bro! i can view chinese words properly now
but why when i click on youku this error keep appearing and i cannot access youku :(
gregory_choo
this youku addon cannot be used, same for the letv addon.
use youkuTV and TTBB addons instead.
Zerogundamw
any good recommendation for app or paid services for VOD content? like Japan/TW/Chinese/Korean drama, Movie etc etc etc
htngwilliam
For the new Xiaomi box 3S, do we need a 4K tv for this to work or any HD tv will do?
ferocity
Do we need a 4K tv for this to work or any HD tv will do?
Where got such thing as need 4k tv then tv box will work? As long any tv that supports hdmi will do lar. You can probably even use it on old CRTs with a hdmi to rgb/rca converter. When a tv box states that it supports 4k, it just means that it can decode and play media up to 3840*2160 resolution. Are you looking to buy your 1st android tv box or what? Because you have been asking quite alot of questions and till now you still have not made up your mind. Dont suggest getting a xiaomi box if this is your 1st box and you are a novice. There are cheaper options out there that are more straight forward to use.
htngwilliam
Just receive the unit and plug into my AV receiver. Realize it doesn't work at I plug it into the HDCP2.2 slot. Manage to resolve it by plugging the HDMI into a non HDCP2.2 box.
This is not my first Xiaomi box. Probably own 2-3 already. Thanks
ferocity
I received my new 4k tv yesterday which has 2x hdmi 2.0 ports that supports hdcp 2.2. I plugged the xiaomi box into this hdmi 2.0 slot and there are no problems whatsoever. Able to change to the max interface resolution of 3840×2160@60hz but its quite laggy so i settled for 1920x1080@60hz instead. Try using your own hdmi cables instead of the white one that came with the xiaomi box. The enclosed xiaomi hdmi cable dont seem to be good.
freezerz
Hi, I have both the XiaoMi Mibox and HiMedia H7N2. Both have their custom launcher. I'm wondering if there is a way to access the classic android desktop interface on these 2 devices. Sorry if this has been asked and answered before. Thanks!
3amcoffee
jialat youku, tudo etc installed from shafa no longer working
anyone has the same problem?
the same apps not working on both my tablet and the new white xiaomi 3s box
PS: i mean a lot more VOD content are now being blocked
deathman91
Wa so confused... so many sellers on qoo10 and like got a lot different gen of xiaomi tv box.
Some sellers have those options that add TV channels all these. Ain't it just installing some programs into the box only? They are charging for that!?
gregory_choo
These are greedy sellers.
However, there are also good sellers, providing free guides to help users to install the free apps.
Ndrew
Some bloodsuckers in Q10 or Sim Lim charge u $10 extra to install Shafa Mkt or/and Kodi another $10 if u just purchase a raw set from them.
Learn to install yourself. They are readily available on youtube videos and just google them.
deathman91
So I just purchase an empty set from any of the sellers?
Read about on some posts that our ISP blocks streaming but they are from 2014. Is it true? In particular SingTel.
Ndrew
Maybe you should try to read greg post refer u to newtvboxsg to see what kind of box u require. He has an excellent list of Q&A on tvbox.
If you want Xiao mi, the best now is Xiaomi 3 Pro ard $99 or cheaper from taobao.
As for ISP, yes I heard singtel maybe have some problem with certain applications but there are always alternative software.
You have to start somewhere and go hands on. For starter u can also get a cheap M8S or MXQ ard $50 to play with first. Learn how to install android Apks and than Kodi.
deathman91
Wanted to try up before buying an android box.
So I tried installing kodi on Windows and tried out the youku app but it always give an error to load the video.
This is from the addon I downloaded from the FB page
