Xiaomi Box Android TV Box
Zoetvbox
Yes. Is shafa installed ? It van help to upgrade
Not sure if this is the right place to ask...
My mum has a Mibox that hasn't been working for awhile (prob 6mths or more), according to her, the apps no longer work. Is there any way to reinstall the apps or install new ones to get it working again?
TimberWolfMk2
Nope, dun think Shafa is installed, looks like the stock app that comes with the Mibox. How do I install new apps onto the Mibox? Will it brick the device? And what are some of the best english apps for it? Sorry for the questions, but I've never used a Mibox before and I'm trying to get it working again for my mum.
PA3131T
Just curious, y nv use a mibox n yet u bought one...
Is it bcos of the branding Xiaomi?
gregory_choo
just uninstall all those useless app, or do a factory reset. it won't brick the device - not so easy to brick, unless you are expert.
for english app, just install movieshd,cartoonhd,mxplayer
shunsuke1984
Just bring it back to the seller and they will restore the apps for you. They usually have two free restore within a year
TimberWolfMk2
Ok after reading thru the thread and some googling, I wanted to install Shafa. Downloaded the apk onto my USB and plugged it to the Mibox. For some reason, my Mibox keeps giving authentication error when I turn it on, even after doing factory reset. Resetting allows me to get into the main menu for a few minutes, and I tried to navigate to my USB drive but it keeps telling me no files are detected. Getting very frustrated with the whole thing. Can any bro help?
gregory_choo
what is the full name of the shafa app downloaded?
TimberWolfMk2
Its 沙发管家.
After much trial and error, finally managed to install Shafa Guanjia and Shafa Zhuodian. Apparently I needed to update the Mibox firmware first which took me more than an hour. And strangely after installing both Shafa apks, it says my storage space is 70% full. Didn't realize the Mibox's internal storage was so limited, then again it seems like my mum bought the older 2nd gen MDZ-06-AA.
Other than kodi or movieshd, are there any good apps to recommend? Mum likes Canto and US dramas. Also would be nice if I can find one to watch the French Open live too.
gregory_choo
Its 沙发管家.
Limited storage is one of the major problem for mibox.
Because of many complaints, xiaomi improved its firmware so that you can use sdcard to expand the storage. However, it is not so straightforward, you have to change the settings at several place to enable the sdcard.
They are many good apps available too.
I suggest you join the facebook group "newtvboxsg". All the info needed can be found there.
Zoetvbox
Kodi is memory killer eg 400mb. With limited space. I would sacrifice kodi, can install 40apps or more to replace.
Its 沙发管家.
Medicated Oil
High Honorary Member
xiaomi 3pro solved those issues.
rooting it makes it even better
Can advise what software did you used to root your box ? kingroot ?
Beside installation of Google Play Store, what are the additional benefits of rooting the box as it will dis-allow the firmware update from xiaomi.
Mi Box 2 does not have a SD card expansion slot. I am not sure whether the new firmware allows the box to install new apk through the use of thumbdrive. This will allow the installation of KODI.
Zoetvbox
Suppose some site is geoblock. The vpn app may need to be root in order to bypass geoblock. Some app can only work if rooted. Once root, u can removed unwanted buildin app by xiaomi.
Medicated Oil
Thanks.
I changed the DNS to bypass geoblock.
They are implementing it on some of the apps liao.
TimberWolfMk2
Anyone using Flytv? Can't seem to get some channels to work...seeing only a black screen with audio in the background.
