Xiaomi Box Android TV Box
whoooo
Tried that but didn't work.
The only configuration that works for me is turning on hardware decoding but uncheck all 3 options under it.
Even turning off software decoding doesn't work. Strange...
And when it work, high bitrate mkv file will stutters.
I am pretty sure the xiaomi box 3 has much better hardware than the raspberry Pi. Hopefully some patches come out soon to utilise the full power of the mi box3.
Try Gotham 13.1 seem that the code was patch and I got no problem with Libstagefright enable but do crash to Dashboard when NediaCodec is check
restore_xp
strange pro by right already support 4k TV.. sorry if this sound rude maybe u run antutu to check if you got the real pro? where u bought it from?
Confirm is xiaomi pro becos no lan port. Able to set the box res 4k2k but screen flicker. All my tv hdmi ports are ver 2.0 but xiaomi is only 1.4
Blindaim
What hz or fps did you choose? HDMI 1.4 only support 4k @30fps
restore_xp
I had used both 24hz and 30hz with the original xiaomi cable and belkin, both also flicker. Will try out with the hdmi2.0 cable that I had order on ebay once it arrived
lingcw
I already stumbled on this solution... but still, thanks for sharing.
A note to those who want to try this, make sure you reboot your XBMC after applying this setting.
Anyway, the high bitrate mkv seems to play smooth now. Hurray!
gregory_choo
Interesting.
What is the resolution for your high bitrate mkv? how about the FPS achieved?
These info can be viewed by airmouse keyboard or by connect a usb keyboard to the box. Press "o" while playing video will bring up these parameter.
what are the figure for drop frame, skip frame, resolution, fps?
Kiddream
Hi all, saw the Mibox Pro selling for $129 on qoo10. That's an option to add $10 to change the menu from Chinese to English. Is this necessary or we can do it ourselves?
Salapi
i think it's just changing the language setting only? :crazy:
Kiddream
Or does it mean flashing another firmware? Also, it says that the box comes jail broken out of the box. Is it the same as root? Abit confused here.
whoooo
Just seller hyping. Install tuzi launcher to get english menu other than xbmc all other app will be in Chinese. Dont get con by yjr seller
lingcw
Interesting.
I left the Mibox3 at my gf place to let her watch world cup.
Will check during the weekend when I am there.
Btw, there is an iOS xbmc remote app. It comes with a keyboard mode.
Any idea if pressing 'o' on this soft keyboard will bring up the parameters you mention above?
My gf don't have a usb keyboard.
gooojeeee
good price and spec
