Xiaomi Box Android TV Box
lingcw
Thanks for the reply.
I installed the XBMC on my Mibox3 but can't get it to work with hardware decoding.
With higher bitrate mkv, the motion are not smooth.
It is worse than my raspberry pi running XBMC.
tckrto
I found something amzing with mibox! Playing music mp3 files it will auto decode and display the lyrics.
gregory_choo
For Gotham, have your try turning on hardware decoding but with the mediacodec option unticked? my H7 works better in this configuration.
cheong
did you install from this file using its instruction?
链接:百度云 请输入提取密码 提取密码:lir0
It should come out after 2-3 reboot, if not, just install the vendor.apk as per other apk. i.e. use file manager to browse and click on it.
show me the screen capture after you did the rw-r--r--
it came out only after a few reboot. thanks
Anyway do you have the method to root the xiaomi gen 3 box ?
sEnG55
hi. after the recent xiaomi software update seems like can't do airplay from my ipad, is the function still available?
I experienced the same issue.. My ipad and macbook cannot detect mibox for airplay after updating to the latest firmware.
bigbob
Guys, i want to do a quick check.. Can you guys view the movies or drama with the red 搜狐 tag? Im having problem but my friend actually can watch. I'm thinking what is the norm?
I have a video to show..
MiBox cannot play red tag movie - YouTube
i also cant watch. guess its geolocked. or maybe isp locked. I'm on m1 fibre, ur fren who can watch using which provider? he got vpn?
tckrto
Yup for Sohu movie is geolock. Work around is to download sohu standalone apk and also download hola apk and turn on hola and you are good to go.
restore_xp
When I set the resolution to 3048×2160, my samsung hu9000 screen keep flicker, anyone out there also facing this problem?
bigbob
There's a hola apk compatible with xiaomi box? Can sic link?
Gausss
anyone can get xmbc to work on new mi box?
tried gotham 13.1 but can seem to get any video out from xmbc?
do i need to install fusion launcher to work?
sEnG55
My fren and I are both on M1.. no VPN and even when he disable his hola, he can view those red tag movies/dramas.. damn weird.
wc1985
Anyone on myrepublic network and using this box? Wondering if the streaming is smooth
Blindaim
Check your friend mibox the network DNS setting is what ip.
lingcw
Tried that but didn't work.
The only configuration that works for me is turning on hardware decoding but uncheck all 3 options under it.
Even turning off software decoding doesn't work. Strange...
And when it work, high bitrate mkv file will stutters.
I am pretty sure the xiaomi box 3 has much better hardware than the raspberry Pi. Hopefully some patches come out soon to utilise the full power of the mi box3.
tribalhere
was wondering why when i click on cctv5 or cctv 5hd on cloud tv, it show me the message Unsupported Protocol Maybe your device does not support this stream...how do we fix this?
