Dew36
- Sep 30, 2002
when i try to turn on root explorer it says sorry the feature cannot be turned on from your device
Got my mibox pro from q0010 also. When they said jailbroken, it seems that it does not mean rooted as it just means you can change IU. You've to root the bugger yourself.
But after rooted and copied the framework, vending, etc... into the required folders (and set permission), it seems that play store would only start for a short while before auto closing again. Can't find a solution yet it seems...
. I've attached the files to my dropbox for the time being.
