Xiaomi Box Android TV Box
wc1985
Geolock lah. Why not download youku and watch from youku? Its not geolock yet for android tv box apps.
Youku is geoblocked for me, on myrepublic using myrepublic DNS and UnoTelly also can't unblock
takeshi_lum
hi,
new to mibox but i dont know how to use the remote when opening apps.
i cant see any selection or cursors in the apps i opened, eg. those video streaming apps.
must i use a keyboard and mouse with it?
denniswko
I encountered an issue today whereby ICNTV is blocking the access to xiaomi's in-streaming programs...error kept showing "用户认证"
Just Me
Me have same problem....:(
Sohu sources cannot be watched been with hola. If using himedia, can bypass with hitv.
I realize if it shows CDN 26 after pressing play button, I can't watch. If CDN 19, no problem. Don't know what does that mean. I am on Orange.
Install togic, iqiyi, pptv,letv,vst and more tv. You are spoilt for choices. I don't watch from CNTV, limited selection.
I owned a xiaomi 2 box before. Icntv has very limited content and sometimes you have to reboot the box due to failed license check. And not too sure about the latest gen but mine used to reboot randomly on occasion.
Youku can play from himedia box without issues
As above
titiju
Definitely not on M1. Youku has TV version, there is a blue tag with XL at the bottom right corner of the app logo. Are you using that?
wc1985
Oh l realised it's because the loading takes a long time then on hardware mode it keeps buffering but on software mode after it finish initial loading it's smooth
Cheesecake321
Mine having the same issue when booting up and showing error on 用户认证. I changed the loader to mui on the setting page cause cannot find the settings to change it to 720. Now Can't even go to the main page and unable to locate all my previous loaded apps. Anyone can help?
bigbob
Guys... anyone still can stream shows from icntv? Mine showing error since last night. Cdn19 and cdn26.
tckrto
My post already mentioned no problem liao.What firmware are you guys using? And did u try to reboot miboox or log off account and login again?
stam
hi guys,
i just bought the xiaomi box 3, but i can't root it to install english menu.
Any kind souls can teach me?? Thanks.
Bustamagic
My Xiaomi TV 2 also can't work liao. Shows error "iCNTV认证已失效". Firmware is 1.3.37. If anyone has a way to overcome this, pls share. Thanks.
titiju
Confirm mine also can't use ICNTV anymore. I am on M1. But I don't use it at all. So no worries for me.
