Xiaomi Box Android TV Box
yeufui
I am using mibox3, how do you guys install and use toggle? I installed the standard apk from google play store, but i couldn't navigate with the remote effectively, gave up and uninstalled it liao...
bigbob
anyone on m1 fibre? any problem with speed? since yest mine drop a lot. use to be able to stream 超清 using wifi smoothly. now on lan can only watch 高清. i restart ont, router still the same. sianz...
gregory_choo
plug in any mouse.
toogle works with mouse or touchscreen
tribalhere
i can't installed 沙发管家 2.6.7 on xiaomi box ver 2....how to installed? i click on the apk but nothing works
hchia
I tried input this DNS 192.241.222.103 in the xiaomi internet setting and all the ICNTV block issues was removed and my streaming for 兔apps is also working fine with smooth streaming.
Currently enjoying watching despicable me 2 with my kids with wired connection.
FYI I am on singtel fibre op 100 mbps plan.
Could me tell me what is the procedure to change the DNS? Thanks!
Kantang
How does the mibox 2 compare with the mibox 3 ? Tempted to get one of these but not sure if the additional $30-40 is worth the upgrade . . .
hchia
Unable able to watch 布丁视频
I am using Xiaomi 3. Presently unable to watch 布丁视频, please help.
hchia
How to watch BBC, CNN and others
Which app is able to watch (1) CNN (2) BBC (3)凤凰资讯台?
XxlwAteRzlxX
owner of mi box 3 , not that sure of mibox 2
mi box 3 has wifi AC (decision point for me) | mibox 2 has ethernet port
mi box 3 quad core | mibox 2... not that sure. i think dual ?
mibox 3 4k display
GY_Ren
does anyone buy from groupon? how is it different from the one offering from qoo10?
zizicheong
Hi anyone here use 1set 2/G xiaomi box with Wireless A/V STB Transmitter Receiver Set so can watch in living room and bed room?
diywee
Xiaomi
hi, anyone to let go Xiaomi on the cheap?
Want to buy and try try
sms 93371961
gregory_choo
why use Wireless A/V STB Transmitter Receiver Set ?
It is cheaper to buy another android box.
