Does Viewqwest Freedom VPN works with xiaomi?
Yes.
There is a VPN option. Not sure if work or not since never subscribe VPN. HaHa
Anyway, Hoping some kind soul in the forum can confirm which VPN best for streaming chinese/HongKong drama.
Seriously, you have been very misleading. I can't find any VPN option on the xiaomi at all!!! Correct me if I'm wrong. I'm also desperately trying to find a VPN configuration in it because my main interest is to watch HK dramas with it. I've been googling around and I read from some chinese forums that there is NO VPN configuration on the xiaomi. You can only do it on the router! Please enlighten which part of the settings menu that you saw the configuration for VPN??
I only bought my xiaomi2 last week. It is jailbroken on xiaomi v1.3.20 but I've yet to watch the HK dramas that I want. A friend of my using the older xiaomi was able to watch everything until recently, which I learnt that they have started geo-blocking. Which means you definitely need VPN to watch the HK dramas.
I can't test with my VPN yet, because i can't find any VPN menu in the xiaomi. Can't test on my router either because my router doesn't have that feature. I intend to buy a new router at the same time upgrade my connection to fibre. Now I'm stuck on whether to get Viewqwest with the FreedomVPN or not. I heard that the FreedomVPN only support certain sites like Hulu, Netflix, PPTV etc. But xiaomi works together with iCNTV to provide the streaming, I read from another thread that FreedomVPN does not support iCNTV. Can someone help rectify this?? As in, can you see the latest HK dramas appear in the main drama menu with FreedomVPN?
If FreedomVPN doesn't work with xiaomi iCNTV, I also have another question. Since Viewqwest FreedomVPN works with PPTV, my xiaomi came installed with PPTV. Will the FreedomVPN works with the PPTV installed on xiaomi to watch HK dramas?
Thanks for reading!!
