Xiaomi Box Android TV Box
rainbow99
try this:
after the installation, go to xbmc setting page and set the level to expert, then go video-acceleration and uncheck all under hardware decode, or set to software decode.
Have done that. Sometimes the installation is so bad that even shortly after first run, before I even finish installing the add-ons, when I select options from the setting screen, it just shows a blank. Then after that, it crashed and restart the first run.
Happened erratically. I thought Kodi 14 would be better than 13, but turned out the same. Sigh.
tckrto
Mine running perfectly fine no root performed, software version 1.3.65 & my box is 2gb version.
hotyrole
Didn't someone posted Taobao seller claimed the 1GB is the latest 4th gen model?
This bro is not receiving the latest but the older 1GB model while the rest of us received the 1GB with wireless AC(no Ethernet port)
i received the 1GB gen with wireless AC (no Ethernet Port)
so which is new ?
asriznet
But official website, is ethernet port while qoo10 is usb port. :s22:
The English official Xiaomi website not updated still showing the older dual-core version.
See HERE for the latest model.
Quad-core 1gb which is what all buyers in Lazada are getting except for 1 I believe.
gregory_choo
I have problem with kodi on one of my set too.
try xbmc 13.2 , much more stable
asriznet
galliano
Is your box rooted?
You can follow the following article to get playstore on your mi box, works for me.
Mi Box Pro/Enhanced 3rdGen-Things I did after I get my Mi Box Pro/Enhanced 3rdGe - Mi Gadgets - Xiaomi MIUI Official Forum
You can skip the fqrouter because it's not necessary for us in SG because I think this applies more for great firewall of China.
Oh i thought jailbreak/rooting was not required.
I already can install XBMC by accessing my NAS.
Figured i could do the same for YouTube.
I guess i have to follow STEP E only?
rainbow99
my installation never comes with a permission request prompt. Is it because I'm not rooted?
asriznet
Nope, I tried doing step E without rooting and it didn't work because Xposed Framework requires root access.
geostrong
anyone able to stream 自定义 channels on togic? added quite a lot latest sources but unable to stream them at all.
rainbow99
I'm a little stuck trying to root the mibox. I refer to the online instructions and I don't get the prompt when I connect the mibox to the pc, can any bro advise why so? I don't understand what's USB驱动 and 调试, is it usb debugging? If so, I don't seem to have the option to enable developer mode, like how it's normally done on phone. Thanks.
3、使用MicroUSB数据线连接盒子与PC;
  给盒子连接电源,并使用MicroUSB数据线(安卓数据线)连接盒子与PC,这里需要注意,首次PC连接盒子时,需要连接电视或使用小米遥控器APP的屏幕映射功能,将盒子上出现的"允许USB调试吗?"窗口中点击"确定",以允许电脑连接盒子;
在打开ADB调试功能后,第一次连接电脑与盒子运行本工具时,需要在盒子上允许USB调试,建议勾选“一律允许使用这台计算机进行调试”。如果连接失败,请检查盒子的USB驱动程序,
asriznet
Settings -> Account & Security(Star in Shield)
1. Unknown sources: Allow / Deny
2. ADB Debugging: On / Off
If you choose Allow or On for above, will get a confirmation message, choose left button to confirm request.
rainbow99
My settings are as follows:
But I don't get the prompt when I connect. Nothing happens when I try to run the 小米盒子增强版ROOT工具III.bat file also.
