Xiaomi Mi Max - Part 2
Gaddy23
Flashing is really easy.. some kind soul posted a great guide a few pages back. Loving the phone more and more. Feels premium enough and you can't beat the price! Selecting photos in gallery by swiping is genius.. helps when you want to delete hundreds of photos..
cokiee
That would be @Dragonguy and @Kelvinti, to whom I am eternally indebted. Hahaha.
Guys wanna check - has anyone used MiMover before to transfer stuff? Am on mi3 and want to transfer my apps and contacts etc over to the max. I'm not so concerned about the apps as these can be separately downloaded and logged into again, but the contacts are crucial. Syncing to Google contacts means that all my contacts in Gmail get synced in also, which I'm not keen on.
Sent from Xiaomi MI 3W using GAGT
DRAGONGUY
Hahaha, don't say until like that la. Just helping nia, small matter.
Ps ar, never try mi mover before. You just try it out, no harm de ba I guess. Not as if the contacts will be disappear in the sender set.
Sidler
Contacts will get transferred over with MiMover
kelvinti
Don't anyhow said lah! :s13:
I just share what I know...anyhow! :s13:
Asphodeli
locked bootloader can only flash official MIUI ROMs without unlocking, I think? unless got way to bypass (e.g. EDL mode)
kelvinti
tempered glass easy to paste ?
3. To Flash to GLOBAL ROM, please unlock MI ACCOUNT, under the link: http://en.miui.com/unlock/ After you have unlocked the MI ACCOUNT and received granted permission SMS, can flash to GLOBAL ROM. If you need any help can contact us.
does everyone of u do that ?
No need to unlock bootie if you are flashing official Xiaomi rom, be it Global Stable or China Stable rom de... :)
This applies to Xiaomi official developer rom as well. :)
pokipoki08
Those who need to unlock additional LTE bands may refer to this post (scroll to bottom). ROOT required.
Note: it's unwise to unlock all LTE bands, some bands not in use at all. Makes battery drain while polling for networks. So, improvise as required.
If you messed up, your phone may NEVER connect to any LTE networks again, so BACKUP!. You should have backups if you flash roms regularly. It's easy to have a flash go bad ie flashing when low on batt, etc.
Partition Backup & Restore by WANAM
Select "Spanner Tool" icon, select backup 1st 100MB (contains imei, serial no., mac addresses etc)
Select ALL partitions except System, Userdata
Backup format: BOTH Compressed backup (tar.gz) & raw partition image (.img)
Then copy to safe remote storage
krvAPqxAhbeb5ot0EPBW-yOTdscf6BewXOUiTNPGI_wC9XOfSjlV3WDqHCx1gWX_AEmi=h900
BTW, there's a new battery endurance champion phone from Xiaomi. It's Redmi Note 4/4x (Snapdragon 625). Full battery test ranking here. Only Mi Max 2 can beat this score.
pokipoki08
xiaomi note 4 and xiaomi note 4X same same but different?
a bit confusing here,
china models, qoo10sg & shopee.sg
note 4x - snapdragon 625
note 4 - helio x20
india models, race course road, export set
both note 4 & note 4x - snapdragon 625
sg models, official mi store lazada, sg warranty
note 4 - snapdragon
taiwan models
have a few extra LTE bands
consensus
pay a bit more ($10-$25) to get official local sg set from lazada mistore with card promo & powerbank bundle
performance-driven, choose helio x20
battery-driven, choose snapdragon 625
helio x20 versions
5GHz supported, with 802.11ac WiFi supported as well.
snapdragon 625 versions
5GHz supported, not 802.11ac WiFi support.
Only 802.11n 2.4/5GHz.
if it's not confusing, it's not Xiaomi.
the next 1-4 months should be exciting. Xiaomi will launch Snapdragon 660 & 835 models, 14nm & 10nm finfet cpu, which will give increased battery & cpu performance than any other models now.
Mi Max should drop price then, or be out-of-stock, just like redmi note 3 after note 4 launch. This years midrange top chip, SD660 will blow last years flagship chips. So, choose & buy according to your needs. I wouldn't buy any models now, unless desperate for a phone.
kelvinti
note 4 - helio x20
note 4 - snapdragon
taiwan models
consensus
helio x20 versions
Super duper awesome information and advice. :)
My next new phone must be a 835 powered..
kelvinti
I found below in the developer option. I think my set is OK.
OMG! To my surprise, my Mi Max in unlocked!? Strange!? I don't even knew that it has been unlocked LOL...
The only thing I know is that I have ever unlocked my bootloader using Mi Unlocked Tool, but I have since flashed back to official Global rom using Miflash. It should has been Locked back... Strange indeed!?
Any expert care to explain what has happened in my case?
kelvinti
I know what is bootloader thingy. I'm just puzzled why my Mi Max remained Unlocked even after I have flashed back to original Global rom lol...
It should has been Locked back, right, by right?
I'm blur sia... Kekeke.
Oinkize
Did you use mi flash to lock back?
