kelvinti
- Jan 5, 2009
Samsung app and MIUI cannot friend friend...
rmbr I turned it off. funny, now cannot find 'miui opt', can direct?So, basically, cannot anyhow turn off MIUI Optimization de..
It affects some functions and apps wor.
We all learn something each day.![]()
rmbr I turned it off. funny, now cannot find 'miui opt' can direct?
just got my mi max.
any good mobile accessories shop in Singapore i can visit ?
to buy tempered glass and casing ???
Cannot get it via OTAUsed the mi max for the past 4 days
Didn't regret getting it! Excellent phone with awesome features and battery life
Happy user here
Edit : 8.2.3.0 is out in updater for global rom
Just done updating..
Wanted to get the export version with higher ram and storage i.e. 3/64 or 4/128 but it seems that reviews are mixed.
Can someone help with my below query?
1. It seems like only those who bought the local sets with warranty (3/32) are not facing problem. Is there anyone who got the 4/128 and have zero problem in terms of sounds, sync, dual sim?
2. Can someone consolidate the finalized flash methods for all three versions of export set mi max? Few hundred posts to read through is no joke. I really read until very blur.
3. I checked with Xiaomi SG and Malaysia and they confirmed that all sets that are not sold under them or their authorized dealer, if spoiled, they will not fix.
4. I was told by traders that China normally produces 2 sets of equipments. The ones for local consumption are often more inferior. The ones manufactured for export are of higher grade. Is there anyone with 2 sets of mi max, 1 by mistore/authorized agents, and another direct from china agents to compare?
5. For those who bought from SLS or online seller, any recommendation for a knowledgeble seller who can flash to miui8 and install google? Or have to trial and error everything base on info here? A seller that I can physically go and consult about the flashing & other issues?
6. For the 4/128 and 3/64, how is online streaming of movies, backing up of photos and data to google drive, email push, dual sim calls n messages, dual apps function, quickball accesss, and speed to connect to free wifi at places like starbucks?
7. From the other thread saw Malaysia will have redmi note 4, 4/64 out. Thinking if to go for this if it officially comes to singapore or to still get a export set of mi max. Mi Max 2 probably will take another 6 months to reach SG and have lesser spare parts compared to all other mi phones? Also Mi Max and RMn4 could be very very obsolete even with the high specs once mi max 2 is out because all newer phones are now using type c port?
I wonder how...any download link for Max Prime?![]()
google app store keep crashing..
cant update apps.![]()
