Xiaomi Mi Max - Part 2
Lil_d3viLz
anyone know how to unlock the bootloader?
Holding down Power + Vol Up and releasing power button upon seeing mi logo....
Got me to another screen showing phone and cable with pcsuite.mi.com
i1magic
My phone tio locked how ah?
Fingerprint doesn't work because of first bootup.
Password doesn't work =.="
I didn't change my PIN
I kana before also. Reboot the phone again. Let it boot up and then leave it there for 2-3 mins.
Try the password again.
Please report back.
kelvinti
You must follow these steps:
Step 01: Apply for Unlocking via webby. A SMS will tell you your application is successful. The SMS usually arrives within 30 minutes.
http://en.miui.com/unlock/
Step 02: Using Mi Unlock Tool to unlcok.
http://en.miui.com/unlock/download_en.html
Follow the subsequent guide/steps accordingly including the correct Volume + Power keys combi to go into the Fastboot mode for Unlocking bootloader as stated.
**It should be VOLUME DOWN + POWER for entering FASTBOOT MODE, not Volume Up + Power!!!
shager
Oy! Mr Salesman, come back to the HTC forums.
kelvinti
Opps!=:p:D ! Kena "manhunt" by Interpol now! Jialat! :s13:
Wait! Let me settle my Mi Max 1 and 2 underground business first lah! Then, I will turn myself in at Bedok Police Station later...:s13:
Lil_d3viLz
Done that. But i still see the cable+phone and pcsuite.mi.com.... can't get past there.
Lil_d3viLz
Haven't you enabled the USB Debugging in the Developer Option after tapping MIUI Version for 8 times?
I tapped tons of time. Enable developer option already.
USB debugging? Check now it is OFF. I turned it on and try again
rootz
PS if this was asked / mentioned before.
Is Mi Max a better performer compared to Mi Max 2? Cause in raw score, it seems like so. Thus, checking. Thanks.
deckcard
Yes i know fast boot. Do I wait there to perform factory reset?
It's not fastboot meaning you hv either press the wrong key combo. You may hv entered recovery instead. You can also get into fastboot by adb command:
Adb reboot fastboot
Techno Pride
Big welcome, bro! :)
Well...:s22:
Go to Settings/Home screen & recents -> turn on Show memory status! ;)
Thanks. I've also upgraded to the latest Global ROM beta 7.5.25 as the 7.5.11 had broken widgets.
I've now also set the lock screen to Skip swipe screen. However, on the lock screen during charging, it now doesn't show how many % of the battery. Does anyone have an idea how to get the battery % back?
Techno Pride
I've bought the MOCOLO full cover screen protector here:
Plue Pear Store / Mi Max Mocolo full cover tempered glass
This MOCOLO screen protector has adhesive only on the sides of the protector, hence it only sticks onto the sides.
After trying two pieces of the white version, both have rainbow effect when viewing from some angles. Sometimes it'll be obvious even staring at the phone straight on, depending on the color of the image on the screen.
Are all full cover protectors for the Mi Max similar?
deckcard
Looks like max will be faster than max 2 becos sd650/2 on max is faster than the sd625 used on max 2. Battery life wise sd625 is better so I'd imagine max 2 being a super long battery life monster with sd625 and 5300mah battery
kelvinti
Is this what you are looking for?
Techno Pride
Referring to the "Charging xx% indicator" on screen. It is shown on Redmi Note 3 Global Beta 7.1.5, but not on Mi Max Global Beta 7.5.25.
cokiee
Hi guys,
question related to watching movies / shows on mi max again please. Once I put the files into the 'movie' folder, do i also put the subtitle files there? I know stock android player doesn't play the subtitles, so am gonna try using MX player after googling.
