Xiaomi Mi Max - Part 2
subprimelive
Noon question : any recommended Chinese stroke keyboard andriod app for typing on mi max2?
I am not good with hanyu pin yin , I prefer to write the Chinese character by stroke and let the app identify the Chinese charactes
kelvinti
So far, I use Google Pinyin app. There is a handwriting function. Fast and furious stroking.:s22:
cscs3
Download the Google one is fine.
Asphodeli
I use swype but i mostly use pinyin. GPGT, in case u find it useful:
kelvinti
I use SwiftKey for English. I use Google Pinyin for handwriting Chinese. I switch between the 2 apps.
Anyway, I hardly write Chinese lah. So, it is okay for me to occasionally switch to Google Pinyin to write some Chinese when in needs. :)
I also don't know how to stroke Pinyin de.
Shib
For handwriting Chinese, do I need to install the Google handwriting app?
Koeyun
Hi there.. anyone has any solution to my problem here? My 16Gb mi max is not able to make any outgoing calls or receive incoming calls after flashing even with different versions of global or china rom. Been trying to fiddle with the network but also failed. T_T Appreciate it if anyone can share any advice, or any shops to recommend for a fix. Thanks guys!
kelvinti
Have you confirmed that your sim card is in perfect working condition?:s11:
pokipoki08
your imei could be corrupted, check phone status
if it is corrupted, google restore imei or qcn
good luck
