You can tell by the miui logo (9 and lightning) that it isn't the EU romshib, is yours eu rom?
my update is 7.11.2 v2. eu rom weekly
Not on EU rom.shib, is yours eu rom?
After about a year of using mi max, my screen is warped. Can see light leaking out from the edge? I went to you tube to learn to remove the back case. Once the back case is removed, the screen moved back to in place. But once I put back the back case, the screen warped again, leaking light. How to solve this?
I think xiaomi can only support fat32. When exfat sdcard is plug in, it'll say corrupted and prompt to format.
Fat32's disadvantage is 4gb max file size.
I got mine changed at Sim Lim for $40. Battery ballooned and popped my screen from the frame. The boss asked... You use your phone while charging? I just laugh & said yes haha
Hmm. When I move my exfat sd card from my Samsung over, it prompts to format. After formatting, it became fat32.Yah. NTFS cannot. But exFAT can.
During charging, the temp is 40+ degrees. Prolonged usage on a regular basis while phone is juicing up will definitely increase the temp even more and stress battery outI got mine changed at Sim Lim for $40. Battery ballooned and popped my screen from the frame. The boss asked... You use your phone while charging? I just laugh & said yes haha
Let's hope that the MIUI 9 Stable rom really come to us in mid November as announced by Xiaomi!![]()
Isn't it already out?
Is the screenshot taken from your Mi Max?Hmm...Is the screenshot taken from your Mi Max?
Yes, got a prompt to update this afternoon.
Nothing so far......
