Xiaomi Mi Max - Part 2
Just Me
Here you are bro.. :(
Mine's mi max prime 128gb
Update : I found the reason.. it's one of the themes in the EU theme shop.. after applying it, it changed the default "whatsapp" icon name to "WA" and that didn't play out well. Thanks...
kelvinti
Haha. ** **** theme maker. Good. :)
kelvinti
Finally, 7.10.19 recognizes DBS Digibank app fingerprint login. :) Awesome. :)
kelvinti
< Correction >
Anyway,
I have enough of running and experiencing MIUI 9 Beta already...
I'm back to eu rom stable 8.5.2.0 for now (Android 7).
I'm waiting patiently for MIUI 9 Stable rom to be rolled out. :)
Techno Pride
I've finally upgraded from 7.5.25 to 7.10.19 Global Beta.
There's something wrong with the auto-brightness feature. When I reboot the phone in a dark room, the auto-brightness starts the brightness setting like 5%? Making it very dark.
kelvinti
Yes. All Android 7 based MIUI rom have this auto brightness issue be it Stable or Beta.
Besides, the manual brightness doesn't stick after disabled auto brightness.
The only solution is to root to edit the auto brightness string from "true" to "false" in the Helium.xml or hydrogen.xml depending on your model.
I did that and it works so well. :)
Auto brightness behaves correctly. No super dim or over bright bugs.
Manual Brightness sticks permanently.
Techno Pride
Thanks.
I shouldn't have upgraded... -.-"
Techno Pride
Now I keep getting mi drop popup alerts.
Googled and found from MIUI forums that it has been an issue since June 2016. Need to change back to default theme. Wtf...
Just Me
This week's EU rom update..
Sausage
something strange happeed on my mi max today
the lock screen resized so it only occupies half the screen. The bottom half of the lock screen is all black. Has anyone encountered this?
kelvinti
Simi version of rom?
