Xiaomi Mi Max - Part 2
kelvinti
Up to date. I have to admit that no rom beats the eu rom!
Below is the list of eu roms based on official China Stable rom and official China Beta rom for your flashing in TWRP. Enjoy! :)
Latest version of TWRP 3.2.0.0 for Mi Max 32GB (Hydrogen) -> Click Here!
Latest version of TWRP 3.2.0.0 for Mi Max Prime (Helium) - Click Here!
Mi Max 32GB (Latest Stable rom):
eu rom Stable MIMAX 9.1.2.0
Mi Max 32GB (Latest Beta rom):
eu rom Beta MIMAX 7.11.30
Mi Max Prime (Latest Stable rom):
eu rom Stable MIMAXPro 9.1.2.0
Mi Max Prime (Latest Beta rom):
eu rom Beta MIMAXPro 7.11.30
ngbc
Yes. All Android 7 based MIUI rom have this auto brightness issue be it Stable or Beta.
Besides, the manual brightness doesn't stick after disabled auto brightness.
The only solution is to root to edit the auto brightness string from "true" to "false" in the Helium.xml or hydrogen.xml depending on your model.
I did that and it works so well. :)
Auto brightness behaves correctly. No super dim or over bright bugs.
Manual Brightness sticks permanently.
Kelvin,
What's the apps you used to edit Helium.xml?
I tried File Expert but it prompt "doesn't support root directory in Android 7" :(
Already root with Magisk v14.
Thanks.
kelvinti
Kelvin,
Thanks.
Ohh! Male it simple. Any text editor will do.
Copy the helium.xml out from root to internal storage using any root explorer and copy it to pc and edit it on pc and then copy it back to internal storage and then copy again to root using root explorer on the phone.:)
Assign Rw-r-r permissions and reboot your phone for it to take effect.
virus2977
My mi max battery came. Diy..... Lol
Sent from HUAWEI TRT-L21A using GAGT
ngbc
Find this FX File Explorer
apps that come with text editor when installed. Done & auto-brightness working now, Thank you!
sjchai75
Thanks bro again for your contribution, I'm in MIUI 9 now!
ngbc
MIUI 9 Global Stable ROM Download Links
Mi Max 32G
Fastboot 1599M
http://bigota.d.miui.com/V9.1.1.0.N...EI_20171109.0000.00_7.0_global_140110afe3.tgz
Recovery 1396M
http://bigota.d.miui.com/V9.1.1.0.NBCMIEI/miui_MIMAXGlobal_V9.1.1.0.NBCMIEI_fba470fff7_7.0.zip
Mi Max 64G/128G
Fastboot 1599M
http://bigota.d.miui.com/V9.1.2.0.N...EI_20171109.0000.00_7.0_global_15ada3b08b.tgz
Recovery 1396M
http://bigota.d.miui.com/V9.1.2.0.NBDMIEI/miui_MIMAX652Global_V9.1.2.0.NBDMIEI_3be468b46d_7.0.zip
MIUI 9 Global Stable ROM Full Changelog
MIUI9 Lightning fast
New - Deep-level system optimizations (08-07)
New - New icons (08-07)
New - New animations for launching and exiting apps (08-07)
New - Simpler Home screen editing (08-07)
New - Introducing Split screen (08-07)
New - Improved Silent mode triggered by the volume button (08-07)
New - Improved readability for the start page of Messaging (08-07)
Highlights
New - Reading mode can turn on and off at sunset and sunrise automatically (05-03)
New - Improved layout and readability for search results in Contacts (06-29)
New - Virus scans and payment scans were merged into Security scan (06-29)
New - Better blocklist rules with the possibility of separated rules for every SIM card (07-10)
New - Switch for turning Battery saver automatically when charged (07-19)
New - New display formats for update logs in Updater (07-25)
New - Search for apps in the Dual apps settings (08-03)
New - Mi Picks gets a new name and a new icon! Meet Apps! (08-21)
New - Quick ball goes back to the edge after 3 seconds of inactivity (08-30)
Optimization - Cleaner removes empty folders better now (07-10)
Optimization - Protection from unintentional tapping for Dial pad (08-08)
Optimization - Redesigned home page (08-24)
Optimization - Devices with rare Bluetooth profiles are hidden in the device list (08-29)
Optimization - Simplified and improved the design of the virus scan result page (09-07)
System
Optimization - Increased system decryption speed (06-23)
Optimization - Devices with rare Bluetooth profiles are hidden in the device list (07-25)
Fix - Home screen loaded too slow with Android 7.1 (06-23)
Fix - Apps changed Wi-Fi connection status without the user's permission (06-23)
Fix - Developer options couldn't be opened using Bahasa Indonesia (08-15)
Fix - Music stayed in the Notification shade after exiting the app (08-15)
Fix - Only Mi TV/Mi Box can be added/shown on Mi Remote app after the update. (08-22)
Fix - WhatsApp force closed in Split screen (08-29)
Fix - Fingerprint sensor works faster now (09-07)
App Lock
New - Added the App lock step before unlocking using a new fingerprint for the first time (08-15)
Contacts
Fix - Contact search didn't work properly for Russian and Ukranian (08-29)
Messaging
Fix - Time in Messaging didn't change when the system was switched to 12-hour format (08-29)
Fix - Messages with one-time passwords disappeared (09-07)
Lockscreen, Status Bar, Notification Bar
Optimization - Notification shade response (07-04)
Fix - Female voice for English (Waiting for Wi-Fi) in the Notification shade (11-02)
Fix - Music player stopped working on the Lock screen after 10-15 minutes (11-02)
Home screen
New - Animated icons for selected apps in the default theme (09-01)
Optimization - Folders open faster (07-10)
Optimization - Users can set their main Home screen in the editing mode (08-29)
Optimization - New animation for launching and closing apps (09-01)
Fix - Couldn't close Recents in some cases (05-09)
Fix - Issues with icon size for Clock, Calendar, and Weather (05-16)
Themes
Camera
Fix - Brightness jumps to maximum when viewing photos (09-12)
Fix - Language support issues (09-12)
Optimization - Improved design for Feedback (05-24)
Settings
Optimization - Introducing Button and gesture shortcuts (09-15)
Optimization - Media volume can be turned back on using volume buttons in DND mode. (09-14)
Optimization - Floating notifications are restricted by default in DND mode. (09-14)
Optimization - Vibration response in DND mode. (09-14)
Optimization - Improved timers for Silent/DND. (09-14)
Fix - Issues with ringtones in dual WhatsApp (05-24)
Fix - Android security patch level was shown with the wrong date (09-07)
Screen Recorder
Fix - The recording couldn't be played regularly after the process of recording was stopped by locking the device (05-12)
Optimization - Launching speed (07-01)
Downloads
New - Downloads keep waiting when the connection is established again in case it was interrupted (09-05)
Browser
Fix - Issues with Urdu (05-24)
Recorder
Fix - Adjustments for Recorder and Second space (06-23)
Calendar
New - New cards: Horoscope, News, Cricket news, and Cricket matches (05-18)
New - Holiday cards for Russia (06-28)
New - Introducing football cards with the info about major international leagues and matches (08-15)
Blocklist
New - Better blocklist rules with the possibility of separated rules for every SIM card (07-14)
Cleaner
Battery Usage
Security
Scanner
Fix - Scanner couldn't work normally (09-12)
Quick Ball
Other
Fix - Google widget disappeared because of the Dual apps (06-20)
Sausage
I'm new to all this. currently using mi max 1 32gb with 8.5.1.0 global stable.
can i just update this?
Mi Max 32G
Fastboot 1599M
Recovery 1396M
what is the difference between fastboot and recovery, and can i just overwrite the 8.5.1.0 global stable with this?
ngbc
Mi Max 32G
Fastboot 1599M
Recovery 1396M
Yes, download the Recovery ROM (1396M) and follow the 1st method in the link below:
http://en.miui.com/thread-736923-1-1.html
Make sure that you backup your Photos, Music, Important Files, Apps, etc. because they might be lost in the Flashing/Upgrading process.
Sausage
the forums say this update has some problems... maybe i'll wait.
