Xiaomi Mi Max - Part 2
kelvinti
I'm not too sure what is what too at the moment. Let me test further later.
Techno Pride
for the latest 7.12.14...
1) can disable the App Vault?
2) Can separate the toggles and notifications into separate menus?
kelvinti
Are you referring to official global beta?
If so, you are forced to use the new notification layout. No Separate is allowed.
As for App Vault. I can't remember now.
If you are referring to eu rom Beta. App Vault can be switched off and you are still given the option to use either the Combined or Separate notification layout.
remoir
Hi
What kind of charging cable should I buy for the phone? I tried using the remax type c cable but it does not fit nicely into the charging port. Anyone can advise me? Thanks
kelvinti
Hi
Cannot use type c lah.
Max 1 uses normal one.
Shib
After update to 7.12.14, the alarm icon always on. Dunno how to remove... Any advice how to check and fix?
Just Me
No issue with mi max prime...
Sent from 白イヌめブコロス using GAGT
killer
Any recommendations for places to buy mimax2 local sets? Was thinking of getting direct from mi store as they should be able to support if there's any issue. Quite uncomfortable about getting export sets due to issues on warranty. Yes, I feel having local warranty is worth the > $100 premium, esp since recently I had to deal with warranty that's overseas
ngbc
From Mi store, $399 for 4+64GB :
https://www.lazada.sg/xiaomi-mi-max...1.4208a8c3eLuBSP&ff=1&time=1513607364&sc=IQsB
tingsters
what is the battery like for max when is updated miui 9 global stable rom will it draining the battery very quickly?
kelvinti
Not sure about it coz I don't bother about the battery life since it is basically already damn lasting. No fight de.. :)
Shib
Another update.
Shib
Merry Christmas. Anyone realize the mi max booting up slower? Took mine around 1 min to power up to ready state. Is there any way to improve boot up speed?
kelvinti
MIUI 8, yes. Slow.
However, MIUI 9, damn freaking fast.
Shib
MIUI 8, yes. Slow.
No difference as far as global beta rom is concerned... If like this, can't imagine those on SD625. When I used 2nd sim, the power up even slower.
