Xiaomi Mi Max - Part 2
kelvinti
As usual, after update, I had to reboot the phone again.
Why:
- network was stuck at 3G (turn off mobile data and on again does not help).
- phone suddenly prompted me Facebook stopped working. But, I do not even use FB on this phone... :s22:
Your sim card or telco lousy de.. Lol..
Such a huge scree phone! So wasted you don't fb it..
I'm running 8.1.9.0 now. All are good so far.
justln
any good SP to recommend?the one i got from nilkin dont cover the whole glass fully, feels sian
https://detail.tmall.com/item.htm?id=531825958585&_u=a1pe8mnma4f5
This one got cover almost all if you choose the colored versions, also covers the black borders.
Edit: Just received unlocking confirmation, can finally unlock bootloader and install TWRP with less issues. :s12:
bladez87
my rooted mi max drain batt dam fast. i think is due to the dual sim network running.
SkimMilk
bahaha... sim card / telco is FOC one. M1, came with my fiber. :s13:
And i said before liao, this is my media phone, that's why I don't activate/use much stuff on it.
This phone can format anytime and I won't lose anything precious. :D
kelvinti
Okay. The low volume issue via earpiece on YouTube and Mi Sound Enhancer are still not fixed in the latest firmware.
Don't know the developers team waiting for WhenTF to fix.... :(
limpingsim98
Why:
Same 2 problem here, getting worse for each new version.
dxboy
Why:
Wa riaos... 2 bad feedback 1 OK... Update or wait..
bladez87
i not facing such an issue with dev rom.
kelvinti
After upgrading, some phones may behave not so nice.
It is always good to reboot one more time to iron out the unsteadiness!
As long as the phone works fine after reboot, it is considered okay liao especially for MIUI ... :)
kelvinti
Just realized that there isn't any Global Developer ROM for Mi Max Prime! WTffffffffFu... :vijayadmin: :o
