Xiaomi Mi Max
i1magic
Wah lau ... I just updated to 6.8.18.
It seems like the "Permission" cannot click "Accept" problem is still there.
*Sian liao leh*
jazzman80
none of the ROM versions which I tried so far is perfect.
like I can't disable the apps on miui 8 onwards.
and bootloop happens if I turn off the miui optimization or other settings (that needs reboot), over on v7.5.3 global ROM.
china ROM though with bloatware, so far OK with reboot.
having to say that, reboot takes so long on xiaomi phones?or only on max?
i1magic
There is no perfect ROM, only ROM with lesser bugs.
i1magic
*Sian liao leh*
Still cannot click on "Allow" leh.
Can anybody confirm?
Oinkize
I was using some PIE control function on some rooted custom ROM. Then when I found this PIE Control which do NOT need root, ho say liao.
Are you a PIE Control user too?
No.i still cannot find a need to use it... Thus i did not activate quick ball feature...
Oinkize
Smartcell will flash to global rom, at least they did for some of us
If india set they do not need to do anything.
If china set, not sure if they flash the official rom or some modified global rom. So got to depend on situation...
sumkong
i can confirm the china set from smartcell is loaded with miui7 global stable rom. so no difference from india set. other sellers, i am not sure.
hpv500
those on stock launcher, is it able to do 5x6 for display icons? am only able to do 4x6 only
