Xiaomi Mi Max
virus2977
I think china rom got the first update to miui 8. Cos i using china rom which i bought is seal box from aliexpress. Before 23 aug already got the update on my phone. Btw china rom got all the china app not bad. Got free movie to watch
Bobby Goh
I using China ROM for my 64gb too. Am contemplating upgrading to the developer ROM cause saw my boss using the clone WhatsApp like very convenient. Now is carrying 2 phones for me.
Oinkize
I am on China miui 8 beta. So far so good...
eurororfd2r
Received my order today and they are with China rom but with playstore installed. Check for update and miui 8 is available so go ahead. Now the updated version for:
1) 32G is 8.0.1.0 (MBCCNDG)
2) 128G is 7.5.6.0 (MBCCNDG)
Check with you guys are the 2 phone China rom official? How to check? (If can check)
I'm OK to stay with china rom with 32G
As for 128G no choice but to stay.
Thanks guys
tan1688
Same for me...just arrived..same box :)
Somehow, my phone pouch I ordered earlier is still not here yet...
Can please post photo after you attached the tempered glass screen protector. How much is your tempered glass screen protector?
walkofwinners
For those guys on China roms, might wanna check if u r on the official China rom or custom ones. Custom ones won't get you ota.
Oinkize
Thanks guys
Your 32gb flash to global ROM since available.
128gb bo pian just leave it as it is...
khaine
After paste give review..
Ok, pasted, now my whole phone is rose gold :p
It makes the screen look slightly thicker, but gives the protection I'm looking for and it's still thin enough that it's still lower than the IPaky rubber edges. Manages to hide the long scratch I have on my screen (dunno how I got it scratched).
Has about 1mm gap all around between it and the IPaky case edges on the front screen. Sort of a white 1mm border now.
Screen is still sensitive enough to scroll and activate the icons without issues
Screen brightness soften now, not so glaring.
Sorry no pictures, dunno where to upload them to link to here
Overall, I will recommend it. Got it from AliExpress from the link someone who also bought it earlier in this forum
https://www.aliexpress.com/snapshot/8008580470.html?orderId=77664063081444
Update: Got the rainbow Newton Rings effect...tried to re-apply but still have...going home tonight to try out that baby powder trick from a link someone mentioned here previously
Also, noticed that the screen protector left/right edge is smaller than the width of the screen as it covers about 2mm of the sides...no impact (ie doesn't cover up) to display of icons
khaine
PSP Emulator
For those who are interested, I managed to install the PSP emulator for Android and can run PSP isos without issue.
The big screen is great and has enough space for the soft keys without blocking the game
Frame rate is good as well.
virus2977
Mine is offical china rom. Come in seal box with plastic.
eurororfd2r
Having trouble with my 128 now. I can't sync my contact nor install my apps from my Google account.
Follow the steps of installing the installer and found I have all the 6 apk from installer but can't install them :(
What have I miss out?
