Xiaomi Mi Max
nuilnuil
Received my order today and they are with China rom but with playstore installed. Check for update and miui 8 is available so go ahead. Now the updated version for:
1) 32G is 8.0.1.0 (MBCCNDG)
2) 128G is 7.5.6.0 (MBCCNDG)
Check with you guys are the 2 phone China rom official? How to check? (If can check)
I'm OK to stay with china rom with 32G
As for 128G no choice but to stay.
Thanks guys
I just got my mimax 64G but the latest china rom is v7.5.4.0.MBDCNDE.
But the rom for mimax 128G for the above bro is different with mine, are there different rom for 64G and 128G?
I also found that the rom v7.5.6.0 is for mimax 32G, so the rom is interchangeable between 32G and 64G/128G?
If that is true, I suspect why some bros already got the OTA updates for MIUI 8 cos their rom is v7.5.6.0 that is already capable of updating to MIUI 8.
kelvinti
It's Friday again! No sight of MIUI8 Global Official rom for Mi Max 32GB yet! :o
However, we will still get the Global Beta 6.8.25 later today! :)
Not that bad!:s22:
ken_oon
what kind of case u using? got pic of the crack?
wXmPrJF
http://imgur.com/wXmPrJF
Using tempered glass screen protector with TPU transparent casing.
That's why i said how strong the glass if hit any corner also breaks lol
eurororfd2r
Thanks guys for your advices. My 128 problem was settled.
Both set came without seal and i guess the seller (New Star) install the installer apk before hand.
I tried clearing cache, clear data and set permission also unable to unstall! So i uninstall playstore and reinstall again to try. Haha solve the problem. Later i will install the rest or my apps and move on to 32G.
I had the full cover white sp and paste it myself (2nd attempt). Will try to upload pic. Bought a cover that can lay landscape gor watvhing moive too.
Lastly thanks guys
Oinkize
32 or 64/128 can be either on miui 7 or miui 8 beta.
But both on different f/w cannot interchange.
Bobby Goh
For those guys on China roms, might wanna check if u r on the official China rom or custom ones. Custom ones won't get you ota.
Mine official China, updated to current 7.5.6 from system update, so is confirm official right? Waiting patiently for the China ROM for 64gb update.
Oinkize
Lastly thanks guys
64/128 more tricky.
32gb on global rom should be easier to setup.
Bobby Goh
Having trouble with my 128 now. I can't sync my contact nor install my apps from my Google account.
Follow the steps of installing the installer and found I have all the 6 apk from installer but can't install them :(
What have I miss out?
I had this issue when I first got my 64gb. From googling and youtube'ing, cleared data and cache for play services fixed it. Have to reboot after clearing. Give it a try.
Niaoson
Anyone has problems with authentication in office networks? Works well at home and elsewhere, only this particular network. Not my password wrong though because other people also cannot log on using my phone but no problem on other phones. Tried Google but no clear solution. Already did all the forget network and join again stuff but still not working. Anyone has any solutions? :o
KingOfSbw
For those who are interested, I managed to install the PSP emulator for Android and can run PSP isos without issue.
The big screen is great and has enough space for the soft keys without blocking the game
Frame rate is good as well.
did it for psx emu...works well too
