Xiaomi Mi Max
azbyza
Yes MIUI China rom will get this kind of problem. It also comes with many ads in built-in app. Try not to use China MIUI.
Sent from Xiaomi MI NOTE LTE using GAGT
I wonder if you have tried to long press on these annoying China apps in the pull down notification panel and when the app settings open, you can off the app's notification?
I did that for every China app that make annoying sound when something appearing in the pull down notification panel. Now my Mi Max is mostly quiet.
charleslee
Just gotten mine from Mobile square. 32Gb version. It's at MUI7, cannot seem to get ota for MUI8.
charleslee
Those who say gmail and whatsapp never auto push, check your settings? Mine working fine, using miui 8 china rom now.
Which setting? I've done the security autostart for WhatsApp, but Gmail is not listed in the apps list to set autostart
HeeroYuy84
can anyone share the eap screenshots for wireless@sg? i am on miui 7 and nothing can be set
Oinkize
So stable is not stable and not stable is stable?
Sibei complicated, just like how women speak
Oops …
You have to experience to understand it. Hard to explain with just words. If you know what i mean...
johnsonheng
what u mean, u saying flash to global rom and install google services or what.
can i flash 32gb global rom on a 128 gb china set.
will brick the phone a not
DRAGONGUY
Because miui 8 global stable is not officially out yet for 32gb mi max. Just wait a bit longer for it.... don't worry, ur set is on official global rom.....
Oinkize
Cannot flash 32gb rom into 128gb.
Just maintain as 128gb china rom and install gapps.
JuXn5566
But the email, WhatsApp won't get push. Quite troublesome
It's not you won't get push totally. Just that it will be much more troublesome as you need to tweak the settings accordingly in order for proper push. Eg. such as toggle apps to auto start in security, don't restrict background activities under battery usage, and maybe lock Whatsapp in the background so that Whatsapp notification won't delay.
But other than push, there are some other problem I faced during my experience with MIUI china rom last time. Eg. Youtube 360/VR video doesn't work, snapchat filter doesn't work.
