kelvinti
- Jan 5, 2009
I think Grey may be nicer.
Matte Grey or Matte Black likes the iPhone 7! Chiu chiu bootie sia...!
As someone mentioned earlier, even external USB via OTG adapter needs to be in FAT32 format. This is one thing I disliked about Xiaomi devices. Last time used the Redmi 1 already had this issue. All my previous Androids (Samsung, Asus, Sony) have no issue read/write onto exFAT microSD cards or USB storage.
didnt know the battery is removeable.![]()
If the casing Can open so easily, meaning the battery can change internally?
yes, battery quite removable. But xm def. won't sell them and 3rd party replacement batteries will only boast 6000mah, but only 3000mah with flickering powerIf the casing Can open so easily, meaning the battery can change internally?
Yupz, no way around it. Just get the bigger 64G/128G Mi Max if you need to store large sized media files (>4GB) on the phone. Xiaomi is really behind in supporting exFAT. FAT32 is damn ancient file system. I think they just not willing to pay the $$$ for it.Does that means if want to store those more then 4g per file movie then must get the 128g version mimax
Bro, can share on where u get the casing?The case I am using is this one with the i-Ring.
With this way, I can reach further and yet the phone will not slip out of my hand.
For me is I keep accidentally pressing the power button! ArghTaking the advice of all here, decided to keep and try out for 2 weeks see howtyping abit not used to cos i kept hitting the back button on the panel haha.
Don't try leh!
We don't want to be number 7...and play Total Recall game here la deh!
gd case for protection but finger print scanner hard to press . . .
