Xiaomi Mi Max
cscs3
Miui-xperts, turning off miui optimisation and hiding system animations should not have any adverse effects right? (Both req. reboots).
What other tips for cleaner runs?
I have system animations turn off.
sumkong
My widgets doesn't work with nova launcher. Am looking to rectify it.
I can't find this security option you mentioned to disable the clear cache when device is locked.
It is not in the setting. Go to the"Tools" folder and tap the security icon.
este87
hi, i have a query. if i were to purchase a 32gb China set and flash it to Global Rom. would there be any difference to a 32gb india set who is alrdy on global rom? thanks in adv :)
i1magic
Battery performance update after latest beta firmware.
So your charts mean battery life improve or degrade?
Seems better. Since I got play Pokemon Go also.
touchme
Thks, updating, will lose root?
Anyway to configure screenshots to save in external sd?
SPEED
My fren just got his mi max from smartcell lazada
still is India set
:s12:
virtualape
those who bought the export set, if it spoils after the 1 month warranty period from the shop, can it be repaired by Xiaomi Singapore service center?
icefox2004
If u got china friend going back china for holiday....u can ask him to bring back china and do the service there. The Export set still go warranty in china.
i1magic
Just buy another set. Keep the spoilt set for the spare parts. So next time, just need to pay for labour for them to do the swop.
