Xiaomi Mi Max
kottty
i just change from 32GB to 128GB ..really can felt the different ..more smooth and fast ..and i personal felt China beta better den global beta .no regret for paying more $120 for the speed ..
sumkong
I have one issue that is my app does not stay on for long after I open it. Usually, we have to close them or else they will stay open. It seems that the phone has a setting to close an app after it has not be use for a while. Anyway to force the app remains open until it is closed manually?
KalTorak
Security > Settings > Battery usage > Set "Clear cache when device is locked" to 'Never'.
Wilberttt
Which rom are you on in the 128GB? Do you get the low volume problem and late notification bugs?
I got convinced by the fellow users here and bought a 32GB global rom one. Very happy with the phone and didn't dare to upgrade to MIUI8. All functions are working very well now.
Just Me
Yah, hurrysep30 is invalid liao. Think the Bros here whacked the MI Max too hard with that code :p
Found another voucher for citibank cards but only 20 bucks off. Try "citiwild".
So, even hurrysep30 has expired for payment via hellopay now..?
I paid my item using hellopay with hurrysep30 yesterday at 234pm..
ya ended alrdy:( maybe wait for oct then
Ended? Just tried applying around 10.55pm.. still valid :s13:
heng_ah
If sideload and can work, likely means it should be playstore problem as the app itself is fine, but playstore blocks the install.
Read on mi forum, one comment guessed is that it's possibly something about the way they validate devices to decide if the app is 'compatible'. Sounds plausible.
Uniqlo app is different issue. Can install from playstore, but crash. Sideload also crash, so this should be developer/app problem.
what are the benefits of installing Uniqlo app?
Normally I dun use app if similar function is available online.
touchme
How is this different from lock app in memory? (found in miui7 previously, but can't find in miui8 now)
Another locking method I found out today, is from Recent Apps> swipe up desired app> press the mini lock symbol, how does this method differs too?
kandinsky
That's my preference too. :) Prefer browser to app unless app interface is an improvement.
Uniqlo sometimes has promos only available in app, like recently they have their 'shake to win' game.
KalTorak
The app lock method you mentioned simply prevents the app from closing when manually freeing up RAM in recent app menu. Can work also but troublesome when you need multiple apps to stay open all the time. I found that apps auto close after phone locked due to that Clear Cache setting so I set it to Never clear cache. All my apps stay open till I manually close them, and I don't use App Lock feature at all. :)
touchme
Miui-xperts, turning off miui optimisation and hiding system animations should not have any adverse effects right? (Both req. reboots).
What other tips for cleaner runs?
