Xiaomi Mi Max
jazzman80
i was attracted to s7 edge,sold it within couple of days as it failed to satisfy me with its battery.
kelvinti
Quality okay for that price lah. Even high priced phone, one drop, wrong angle of impact also cracks like powder!
One thing for sure that cheap phone is no good is the low light camera shots.....vomit blood one including this Mi Max...!
If you want good low light shots, then you can forget about Mi Max altogether! :s13:
Bobby Goh
Tada...
If you lazy to update always.... i suggest u download the eu stable 8.0.3...
Thank you. Finally can put my 64 GB to better use, than being just a portable cinema...
benny888
Has anyone found a good car mount for the Max? My current one which works with my Nexus 6P won't fit the Max. I searched Qoo10 and most won't fit phones with screen size over 6 inches.
I am using Capdase with extendable side claps . It fits the phone perfectly . Bought many years ago and no idea whether is still around. Try looking for this brand and I am sure my model would had been upgraded by now
kottty
i use those magnet car mount ,any size can use ..best ever car mount i used .is so convenient ..
THIANHOE
I'm using the Samsung car mount. Can fit nicely by "squeezing" it in.
canonrow
Very frustrated using TuneIn Radio app on my Mi Max local set!! It kept shutting down after few mins after I turn off screen (intended to let it run in background, listen music via Bluetooth). I've turned on all possible setting/permissions, esp in battery usage, No restrictions & Allow background Location. Can't seem to find anything else to turn on/off to let it run peacefully in background!!
Anyone has any suggestion that I could have missed? Thanks.
iguoh
Did you try turning off MIUI power saving for the TuneIn app?
KalTorak
Have you tried:
Security > Settings > Battery usage > Set "Clear cache when device is locked" to 'Never'.
